New owner of BX1500 - maintenance
   / New owner of BX1500 - maintenance #11
Congratulations on your purchase. I traded my BX1500 to a BX2350 this year after owning it for 3 years. Never had any problems with it. Not even the Kubota tires that won't hold air thing. It is one fine mowing machine that can also pull tractor implements. Didn't have the front end loader on my BX since I had a loader on my B7800. Watch that your hoses don't rub anywhere when operating the loader. If you take mowing deck off and reinstall, make sure drive shaft has clicked back into place and locked back on. You'll understand when you do it. If you never do it then it won't matter. Mine idled a bit rough unless the throttle was advanced a bit but I never considered that a problem. I just gave it a bit more fuel at idle.
Sit on it near the end of your drive when your neighbors are going to or from work so they can ask you alot of questions or start viscious rumors about you to get you out of the neighborhood. Yes, my neighbor went through 2 or 3 different "mowers" before he finally bought a BX1800 then traded that for a BX2350 with FEL last year.
   / New owner of BX1500 - maintenance #12
I looked at your picture, that looks like a nice machine. Good price also. I bet if you priced a new deck and end loader for that through Kubota, it would be almost $5000. You got a good deal.
Mine idles "rough" but I believe it is because of the inline 2 cylinder vs a 3 cylinder. I guess I will clarify when I say rough I mean the motor shakes pretty good which rattles the hood at the lowest idle. When you increase the rpm's it smooth's out. I don't see it as an issue especially if it smooths out as rpm's increase.
When I seen this I had hard time finding one to compare to see what it was worth. In the end I see now that it ended up as a good deal. I know I will really like this little guy and so will my back. :D
   / New owner of BX1500 - maintenance #14
I priced a new 48'' mmm for $1450.
I don't know what a new FEL runs.
   / New owner of BX1500 - maintenance #15
RobR said:
Here are some pictures of my 2003 BX1500.
These are of my New BX1500.
http://s283.photobucket.com/albums/kk286/lb59/?action=view&current=100_2556.jpg
http://s283.photobucket.com/albums/kk286/lb59/?action=view&current=100_2349.jpg
http://s283.photobucket.com/albums/kk286/lb59/?action=view&current=100_2318.jpg
   / New owner of BX1500 - maintenance #16
1*I don't see it as an issue especially if it smooths out as rpm's increase.
2*In the end I see now that it ended up as a good deal. 3*I know I will really like this little guy and so will my back. :D
1*As far as I'm concerned it's a non issue.
2*You did good.
3*like it ? you'll love it!
Congrats!
   / New owner of BX1500 - maintenance #17
I bought the BX1500 that Jonh Thomas traded in but I didnt know it at the time. He is in the next state over from me and I bought a larger tractor and asked the dealer if he had any good used mowers and I ended up buying a BX1500 with 104 hours and a 54" MMM and a grill guard and they did the 100 hour service beforethey delivered. I paid $5500.00 so I would say you got a great deal. Yes it vibrates at low idle but its not an issue its inherent to the 2 cyl engine. I have read that the 2 cyl motors will last just as longas the 3 cyl. It runs the 54" MMM just fine even in tall grass. Enjoy
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
