BX snow removal or 1000lb ATV?
   / BX snow removal or 1000lb ATV? #31
The plastic windows arent too bad. The only issue is fogging up. I wouldnt want to use the cab during the summer time as it would scratch up easy. Stays nice and warm though!
   / BX snow removal or 1000lb ATV? #32
which one would be better? I already have the atv with blade so the question is should I buy a rear blade for my BX24? Does anyone make a front blade for this without the $1800 kwikhitch setup from Kubota? We do not get a whole lot of snow here (Northern Virginia). $ wise the only thing that makes sense is probably the rear blade or stick with the ATV. It does great but a new tractor toy is always good. I also posted in attachments...a combo rear landscape rake and rear blade unit would be awesome but I have not seen one.
any feedback?
Which one has heat?
   / BX snow removal or 1000lb ATV? #33
Thanks for the feedback..That's what I needed to know...By the way, Kubota should use the type of plow you have. Looks like it may be more like an ATV type plow than the truck type one I have (it's too heavy)..How does that do on gravel? This monstrosity of a blade that I have wants to tear driveways apart unless they are frozen solid...My ATV never did that.
   / BX snow removal or 1000lb ATV? #34
It would do fine on a driveway, nice big shoes on the bottom. My drive is tar but I do plow my walkway and its pea stone. Doesnt seem to be a problem if i keep the blade up just a whisker.
The UTV puts out enough heat to keep the cabil warm enough so a heavy sweatshirt is all I need plowing. I may try one of those dash defrosters that plug into the cig lighter port.
   / BX snow removal or 1000lb ATV? #35
I have a BX23 with the kubota 4 way plow and a Polaris Quad with a plow lifted by a winch and I believe that they work very well together. I have about 750 feet of gravel drive and use the quad when the snow is light and the BX when the snow is deep or heavy. I also use the BX to move the banks back and have had more than a few snowfalls that the quad just seemed to be working too hard due to the weight of the snow. I tried to buy a snowblower for the Kubota this year but was told that it may come next summer and told the salesman to forget it.
I was able to pick up a deere 49 tall chute snowblower for my 318 so my snow removal team is now complete let it snow let it snow.
   / BX snow removal or 1000lb ATV? #36
I'm kicking around building a clamp on snow plow mount on my FEL bucket to use my 60" quad blade with. My tractor could do it all then.:cool:
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2021 BOBCAT T770 SKID STEER (A51246)
2021 BOBCAT T770...
40' CONTAINER (A51244)
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
Kubota SSV75 Compact Wheel Loader Skid Steer (A51691)
Kubota SSV75...
