FMC brushcutter and ???
   / FMC brushcutter and ??? #1
kenstrac
Platinum Member, RIP
So central NH.
Kioti DK 45
Many years ago I went to an auction and they had a FMC brush cutter that was powered by the PTO to a tire then to a round disk just below the deck (no gear box) ,also on my travels I ran across a what I call a large string trimmer, It had a hyd pump on the PTO which ran a hyd motor on the motor was attached a round plate that had instead of string were using old v belts and was offset to the right side of tractor.
My question is has anybody seen or owned any of these ,and if so what was your experience with them.
Any Pictures?
   / FMC brushcutter and ??? #2
Any Pictures?
Here's a picture of bush hog that is driven by a wheel, which itself is driven by the PTO shaft. It's not a good picture but you can get the idea. If you look real close, you can just barely see the edge of tire sticking out a little bit in front of the top part of the shroud.
The good part about this wheel driven set up was that it acted as it's own slip clutch when the wheel slipped on the round plate, whenver you hit something hard. Interesting design.
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
2019 Nissan Sentra Passenger Car (A51694)
2019 Nissan Sentra...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
