Chainsaw Issues
   / Chainsaw Issues #1
charliepff
Harpers Ferry, WV
2516 Mahindra w/backhoe
Since I always lirk I figured I would let you guys take a try at this before I try to fix it or buy a new one. I have a Husqavarna 350 chainsaw. Today when I was cutting I noticed it got really hot. I did not think that was good due to the fact it was about 25 degrees out the whole day. So I refueled it and left it cool down. Well when I came back to run it I cut about 3 logs with it and then there was a thud almost what you would here with the spark plug out and your finger up against the cylinder whole. When this happened I notice the plastic cover move. It would not then restart. So when I removed the cover I noticed the spark plug was out of the cylinder. I though maybe it was loose but I do not think that was it. I noticed all the threads are for the most part stripped out. I have had the saw since 2001 and it gets used extremely hard. I do not skimp on the maintenance either. Is there anything I should look for when I take it apart and is it even worth fixing if the cylinder is shot. Thanks guys ahead of time for the help.
   / Chainsaw Issues #2
Check with a shop and see if it can be bored out and a Helicoil installed. You can probably do it yourself if you are a bit handy.
   / Chainsaw Issues #3
sounds like your mix was off in the fuel.
the oil in the fuel is what helps cool the engine. Under oiled will cause it to run hot.
   / Chainsaw Issues
I did shake the mix up before I fueled it but it is old fuel too. I was thinking of the heli coil but I was wondering if I should look to see if anything else is damaged or anyone else have had this happen to them.
   / Chainsaw Issues #5
Helicoil will fix your head. Id pull the cylinder off and check for damage to cyl or rings too . If theres any scratching, a quick hone and rings will fix you up (should be under $30) Even if you got to replace the cylinder it shouldnt be that bad (around $100 if i remember what i paid for my spacing saw). Put the helicoil in when its off. Pulling the cyl off isnt hard and gaskets are cheap. Id also take a torch and burn any oil or deposits out of the muffler while i was at it. Id definitely try to fix it before i threw it out. I also only use husky oil and fresh "supreme" gas. Im not a big fan of cheap mixing oil.
   / Chainsaw Issues #6
A friend who is an Arborist told me that too; have done it for years in dirt bike, saws, trimmer etc.
Run Premuim gas, with a good quality oil(I use Husky or Stihl, in the little bottles to mix a gallon at a time). Chain saws are a 10,000+rpm motor. They're like a little race motor.
   / Chainsaw Issues
Thanks guy's for the suggestions. I usually do not run cheap gas. I did not take it apart yet but did price a head. The head was $240 dollars through a online parts store. That was just for the head. I am looking at Stihl specials and will take apart the Husky this weekend.
   / Chainsaw Issues #8
I know a guy who runs AvGas in his. Says it works quite well. I'm not sure about the legality or health safety of it, though. I personally use 92 octane with synthetic 2 cycle oil.
   / Chainsaw Issues #9
If you have used the saw well and long it may be advisable to take a serious look at a replacement saw unless the fix on yours is quite inexpensive.:D
   / Chainsaw Issues #10
My saw guy told me to run only high test gas, as it will run cooler.
Brian
23222 (A50323)
23222 (A50323)
8 Ft Fork Extensions (A50322)
8 Ft Fork...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2018 UTILITY VS2DC 53FT REEFER TRAILER (A52141)
2018 UTILITY VS2DC...
2015 JCB 320T ECO SKID STEER (A51242)
2015 JCB 320T ECO...
