NEW: MF 1600 Series
   / NEW: MF 1600 Series #11
I like it. Looks like a GC series on steroids :cool:
I've heard some people comment that their 1500's head lights are not very good at night. Wonder if these will be an improvement?
I am very pleased with the lights on my 1547. High and low beam, Hella brand halogen lights in the grill. They seem equal to halogen headlights on a car. Great for distance on high, (not needed for tractor work, but would be good for transport) good close up coverage on low, then the cab lights fill in the rest, illuminating the front wheels and bucket/forks.
Did I say I was pleased with my 1500 series lighting?:D
   / NEW: MF 1600 Series #12
it would be nice to have 2 sets of headlights like on that big one. loader work at night would be easier
Yea, notice the one pulling the trailer, the top headlights wrap around the side, pointing out to each side. Between those and the four cab lights, the nighttime would be like daytime.
   / NEW: MF 1600 Series #13
They aren't (when using the loader as the loader blocks the light).
No backup lights either, so operating after dark is quite the exercise.
   / NEW: MF 1600 Series #14
Ours are fine, but we don't have a loader.
   / NEW: MF 1600 Series #15
It kind of looks like they were trying to make this new series look like their new big brother, but by only putting double headlights instead of 5 on each side, the look comes off like the tractor is "mad" like others stated. I'd love more lights!
I have a cab series so the cab headlights help a little when doing loader work at night. The cab also has back lights which I use quite often. Even with the etra lights the cab model offers, I'd still like to have more lights!
Did I mention I'd love more lights? ;)
Some of the new features:
Platform:
* Wider Platforms on ROPS and Cab Versions
* Controls placed for more operator room and accessibility
* Deluxe Suspension Seat with Arm Rests
Right Hand Console:
* Redisgned and Raised for easier operation of multiple functions
* Joystick repositioned for better control and out of the way when not in use
Hood:
* New Tilt up one piece STEEL Hood
* Gas Struts on Hood
* Basic Service Points accessibile without lifting hood
* Easier access to battery, air filters, radiator and radiator screen
Auxillary Remotes:
* Option of up up to 3 sets of Remote Couplers
* 1 Set Remotes Standard on Cab Tractors
* Levers are tiered and angled on RH Console for easy operation
Headlights:
* 4 Front headlights for improved lighting
* Placed higher for minimal interference when using loader or front mounted implements
Left Hand Turning Brakes on Hydrostat Models:
* Allows tighter turns with use of brakes on LH Side and Hydro controls on RH side
Cab:
* Recirculation filter in rear of cab alows choice of air flow from outside or interior.
* Cloth Cab Roof Material for better durability especially in cold weather climates
* Nicer fit and finish with cloth interior
ROPS:
* Flasher Lights moved to ROPS with Metal Guards. Better Visibility
* ROPS tilted forward for increased safety. Top is more overhead the operator.
* Vibration reduction plate on ROPS Pivot Point to reduce vibration.
Tilt Steering:
* 3 Position tilt steering lever lowered on Synchro and Power Shuttle for less leg movement to adjust. Hydro not changed due to LH Brakes
4WD Engagement:
* Push/Pull Engagement/Disengagement for clear and easy operation
Hydraulics:
* Improved Flow for smoother operation
* New Mesh Strainer Suction Filter
* Less Bends in Hydraulic Lines for Smother Hydraulic Operation
NEW DL120 and DL130 Loaders for the 1600 Series with curved arm design like DL Series on Utility Tractors.
Most all attachments for 1500 Series will work on the new 1600 Series. Many use current subframe design and drivelines.
I would visit your local Massey Ferguson Dealer for Pricing, Exact Specifiactions and more Product Details. Dealer Launch Beginning in April.
   / NEW: MF 1600 Series #17
Wow. That's quite a list. The only gripes I had with my 1500 series was lack of height adjustable seat, noisy vibrating ROPS pivot, and poor lighting while using the loader.
Looks like two of them are addressed. Hopefully the seat is now height adjustable.
Kudos to MF for improving the compact line-up.
   / NEW: MF 1600 Series #18
I sure it take some time to get used to the new look but they arent too bad.
   / NEW: MF 1600 Series #19
I'm sorry, but they're ugly. Somebody said it, a 23xx on steroids. Kind of reminds me of Kubota's change from xx30s to xx40s, they are ugly, too. Glad I have a 1500 series. I'm sure plenty of other people will think they're OK and happily part with the money.
   / NEW: MF 1600 Series #20
Any more news on the new 1600 series? I've been looking at the 1540, but they're a little "short" on leg room. :( If the 1600's have a little larger chasis, they might be just what I need. :cool:
sf
2008 Caterpillar 45kW C4.4 3-Phase T/A Towable Diesel Generator (A51691)
2008 Caterpillar...
2004 20ft Explorer Pontoon Boat and Trailer (A51573)
2004 20ft Explorer...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51246)
2003 JOHN DEERE...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
