rear balde for 50hp tractor
   / rear balde for 50hp tractor #1
Atobuk2001
Battle Creek, MI
Kubota L4740 HST 4wd
What would be the correct weight for a 7 foot blade, on a 50hp tractor, for snow removal. My dealer wants me to buy one that weighs 320lbs. I don't think this is enough since my B7500(21hp) I traded in rear blade had to weight atleast 200lbs. This tractor has over twice the 3pt lifting capacity as the B7500.
   / rear balde for 50hp tractor #2
Atobuk, Not sure there is a correct size, it all depends on what your going to do with the implement. I can tell you that the 7' Rhino that I use weigh's about 400# and works well with a 60hp tractor. More it weighs, the deeper it can cut when needed. JMHO :)
   / rear balde for 50hp tractor #3
That seems pretty light to me. I run a Landpride RB3584 rear blade. It's 7ft. (84") and it weights in at 533lbs. It's pretty heavy duty, probably the heaviest model they make without going to the hydraulically swing/tilt models. I am running it on a 45hp tractor.
http://www.landpride.com/ari/attach/lp/public/specs/301-131s.pdf
   / rear balde for 50hp tractor #4
If it were me , I would run the same LP blade that mark. r is running. You might get by with a LP RB2584 though, it is rated for 25-60hp and weighs 396lbs. That might be ok for snow, but I would not use it for dirt, but that is just me.
Good luck
   / rear balde for 50hp tractor #5
Good luck
That's a good point. I've used it for both snow clearing on asphalt as well as moving lots of dirt. I used it along with my loader w/tooth bar to build my driveway extension.
   / rear balde for 50hp tractor #6
Mark, does your tractor lift your rear blade high enough for you? It seems to me that the hitch point on most of the rear blades need to be redesigned. I know that I am going to rework mine.
   / rear balde for 50hp tractor #7
For the most yes. In other words if I'm using it raises it sufficiently in terms of height. If I know I am not going to use it for awhile and it is on the tractor than I will shorten the top link to increase height? Does that make sense?
   / rear balde for 50hp tractor #8
Hmmmm, it looks like 10 pounds per tractor hp would be a good rule of thumb. 200# for your 21 hp B7500. Your 50 hp tractor should then have one around 500#. Makes sense to me as a "minimum" rule. More weight will make the implement more productive and less prone to breakage.
jb
   / rear balde for 50hp tractor #9
That is the same thing that I do, but I still want a little more height. I feel that the boom should be parallel to the ground when working.
Just my opinion
   / rear balde for 50hp tractor #10
jb
That sounds like it is a good rule to start with. I know that I twisted up my first rear blade, and it was 680lbs I think. My new one is 1130lbs and rated for a 15,000lb machine. I don't think that I will have any problems with the new one.:D
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2010 Case 660 Trencher (A50322)
2010 Case 660...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
