Just found this site and thought maybe someone can help. Have a MF135 with an ad152 perkins. Bought it as a basket case, engine out and all apart.Have experience rebuilding before this project. Now the problem,engine has new crank, all bearing clearances checked. New oil pump. oil pressure gauge very erratic when running.removed oil pan and riged up pressureoil feed to engine. No big leaks untill I turned the engine with a wrench. Large leak in front cover. Removed cover, leak occurs when idler gear lube hole lines up with hole on the boss the gear rides on. No serial number on block,nadda,zip. was ther a change up in the blocks,hub and gear? or is a restrictor plug missing? (whew) sorry for the long story but does anybody have any ideas? thanks in advance Paul Jaffer
Soundguy,Thanks but the gauge is showing the problem, every time the hole in the idler gear lines up with the hole in the hub that it rides on the oil pressure drops off to almost nothing. As soon as they don't line up oil pressure is normal. Flusher, VERY nice job on the old girl. I guess what I need is someone with a set of Perkins parts books with the different years to see if there is some mis-matched parts on the front of this engine. thanks Paul
Finaly got a little time before work to catch up here. Farmwithjunk, if you have part books for the different years I need to see if there is different part numbers for different years when it comes to the gear train and idler hub.My best guess is that a replacement short block was fitted(or empty block) before I got this tractor. Then they used the orignial gear train and that is when the problem started. When I got the tractor the rod bearings were wiped out and the crankshaft was .070 thousands out of round. One new rod and a new crank, pistons and sleeves and valve job later and here I amThanks Paul
Hi jaf haven't spoken to the boss yet but have been looking in old parts and service manuals and cant find a change in stub, gear or bush but have also been thinking some one hasen't drilled out the bush and gear maybe allowing too much oil flow but have also been thinking maybe it is your gauge due to that when the engine is running the time that the hole lines up would not be long enough to make the gauge jump of course you are getting a big leak winding it over by hand because you are not as quick as the engine running, i.e. with the engine at idle 750/800 rpm this hole is lining up 375/400 times a minute is your gauge jumping this quick ? If not check your pickup tube is not cracked or warped where it goes onto the oil pump maybe you are getting cavitation causing the problem best way to chack with engine running is to put a fitting into oil gallery and return it back to the oil filler hole start the engine and check for constant stream of oil ( best done with two people 1 to hold hose 1 to operate starter and stopper) Just a bit of food for thought![]()
I'm following this thread with interest. Thinking way outta the box here and making a WAG.. is there possibly an oil slinger ( diverter) that has disintegrated that might used to have redirected some of that flow.. I know some engines use them.. like on the camsshaft on a flatty ford N.. etc. again.. wag...
soundguy
Hi Guys, Been reading all the replys and thanks for the tips. Allready installed a new oil pump and pickup. Did the oil line off the engine with it running and watched it start and stop flowing. the problem is so pronounced that I don't get oil to the top of the engine. I took a reclaim refridgerant tank and filled it with oil and pressure fed it to the engine both running and stopped. Then I get oil to the top of the engine. Does anybody have the block parts list? Maybe a plug missing? It reminds me of a Detroit Deisel with the plugs missing from the crankshaft. Thanks for the help guys, Paul
Hope this helps.
QUOTE]
Oops. That was the MF-135 Continential gasser. Here's the MF-135 diesel engine stuff. Sorry about that.
