Kubota Pallet Forks
   / Kubota Pallet Forks #11
What are you looking to lift with them? LBrown59 made some very lightweight forks out of lumber. Probably couldn't lift more than a couple of hundred pounds, but may just do the trick.
   / Kubota Pallet Forks #12
Jeff,
Try the local forklift dealer. I picked up a 16 in carriage and two forks for $160.00.
I then welded brackets on the back to fit my Power-Trac. I cut a hole in the tip on one fork and installed a 2 in ball for moving trailers.
   / Kubota Pallet Forks #13
2 questions what lenght of forks?? and has anyone ever put a sideshift carriage on a loader and welded a quick plate to it??
Thanks again to all for the ideas. The Kubota dealer said that Kubota raised the price on the forks for 2009, so they'd be around $850. This still sounds high, so I think I'll keep an eye out for a better deal elsewhere.
   / Kubota Pallet Forks #15
I am with the make your own crowd. I talked to the local Cat lift truck dealer told them what I had in mind. They salvaged the parts I needed over a couple of months and sold to me at scrap price. I then assembled my own. These are on a Deere loader but you can buy mounting plates for your tractor for around $100.00 and mount the parts to it. I wish they were wider but for $50.00 I can't complain.
Dan
   / Kubota Pallet Forks #16
I paid $850 for a set of 3700lb capacity from Horst welding out of canada.
   / Kubota Pallet Forks #17
I purchased a side-shift carriage from a forklift place, but I am only using the part that holds the forks. I just welded brackets to the back to fit my Power-Trac. My forks are 36 in, but you can make some extenders out of 6 in channel.
   / Kubota Pallet Forks #18
I give $525 for a nice set of medium duty Skid Steer QA forks from a local implement dealer off of his yard. I think they had been setting for a while and he wanted to move them. US made and rated for 3600# and 42" width way more than my loader will lift. Look around at the off brand smaller lots and you may find it a lot cheaper.
   / Kubota Pallet Forks #19
My understanding is that the Kubota Loader (LA854) Quick-Attach is compatible with standard "skid steer" implements.
If this is true, are the Kubota forks typically a good deal, or can I get a better deal elsewhere (or maybe buy kubota or non-kubota used?) The kubota forks plus frame list for $1085.
Thanks,
Jeff
I have three sets of Skidsteer QA forks, but you are not close enough to avoid the high cost on shipping.
   / Kubota Pallet Forks #20
J_J How much are you asking for your forks?
Thanks
2019 ISUSZU NPR BOX TRUCK (A54607)
2019 ISUSZU NPR...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2840 (A54757)
2840 (A54757)
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
