Top link only shortens from one end??
   / Top link only shortens from one end?? #1
FrogLick
South Central KY
Kubota B3030HSD
I needed to hook up a new implement that required shortening the top link from my more common length but only one end of the top link would screw into the turn buckle part. Both ends are threaded and even with one end screwed in all the way I'm still a little long to make the connection easily. One end of the turn buckle has a hex nut that I thought was a lock nut but it appears to be welded (?) and even a wrench won't get that end of the link to screw either in or out; the other end can be easily adjusted by hand. I'd really like to adjust this length correctly and with both ends screwed in an equal amount but can't figure out why one end won't budge. I'm really stumped so any ideas would be appreciated.
   / Top link only shortens from one end?? #2
The nut is a lock nut and it shouldn't be welded. However, make sure you are trying to move it in the proper direction with your wrench as this threading may be reverse. I always forget what direction to turn this nut to unlock it, so I have marked this with paint on my tractor so I do not inadvertantly tighten it rather than loosen it. You may have been tightening it all along. Use lots of liquid wrench first to break it free. In the future, when you do break it free, disassemble it entirely, apply lithium grease to the threads, and this will help to keep it moving freely. Then remember, or mark the lock nut so you turn it the proper direction so as not to tighten it by mistake.
It was always my impression that this nut was a locknut but I can't seem to free it no matter which way I try to turn using plenty of penetrating oil and force. That and also looking at it carefully made me think that maybe it was welded to the turnbuckle part, but maybe it's just a really good paint job! No paint would hold it against the force I've tried but I'll try again when I get some time. Unfortunately there's no flat spot on the turnbuckle part so using a second wrench on there to turn against is a problem. Maybe a little heat is in order?
   / Top link only shortens from one end?? #4
I'd probably put it in a vise or use a pipe wrench to hold the barrel while turning the nut, and all the top link lock nuts I've had experience with were right handed thread; i.e., as you turn it to move it away from the barrel of the link.
I did put it in a vise but maybe just didn't really apply enough force worrying about breaking something and then really being out of commission. If I ever get this thing loose I certainly won't tighten it up this much in the future. Then again, maybe just implement vibration and normal stresses got it all really tight in the first place.
   / Top link only shortens from one end?? #6
Sometimes a little "impact" action is required. Smack the wrench with a hammer...after you've determined which way loosens the nut...:)
If all else fails, go to store and get a replacement...aftermarket ones usually aren't that expensive.
   / Top link only shortens from one end?? #7
Sitting here can not remember which direction the top part with the lock nut is on my small Kubota and can not remember but is there not two little squares welded on the side of the barrel that will give shoulders for a pipe wrench? At same time the lock nut on mine has a little piece of round rod welded to it and that might be what makes it look like it is welded to the barrel. If I do not tighten the lock nut on mine it will vibrate in use changing the length. It is my guess yours is so tight from not being used. I rather leave mine on the tractor and break it loose there. Back to which direction it turns, one end has left handed threads and the other right hand so which ever way the end that will turns does, this one is opposite.
   / Top link only shortens from one end?? #8
The nut is normal (righty tighty). The other end of the top link is abnormal (Lefty tighty)
I use 2 big adjustable wrenches and whack the one with the other - works every time.
jb
   / Top link only shortens from one end?? #9
As the one end turns you can determine the direction to turn the nut by holding both ends in place and turning the center portion. I know the one end will not turn but it will give you the proper direction.
Place a hammer under the stuck nut and give it a good whack with another hammer. Do this on several different flats.:D
Snipes may also help.
Another way to figure out which direction is to place your fingernail on a thread and then turn the turnbuckle. You can watch which way your fingernail goes.:D
2006 Ford F-150 Crew Cab Pickup Truck (A50323)
2006 Ford F-150...
2011 Dodge 2500 Big Horn Pickup (RUNS) (TITLE) (A50774)
2011 Dodge 2500...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2018 Dodge Journey SUV (A50324)
2018 Dodge Journey...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
