Top link only shortens from one end??
   / Top link only shortens from one end?? #11
I had one lock up on my tractor. I finally got the lock nut loose but couldn't turn the adjustment. No matter what I tried, it wouldn't budge. Heat, 24" pipe wrench and a cheater bar on that. Started crushing and twisting the link. Ended up buying a new link for $20. I packed the lower end with white grease. That's where water sits and rusts the threads. The top adjuster is just greased. Haven't had a problem since.
   / Top link only shortens from one end?? #12
Did you remember that one goes clockwise and the other counterclockwise? It could be that you (or someone else before you) were trying to loosen it, but were actually tightening it more and more, until it froze.
You might put some WD-40 on it, let it sit a few days, put it in the freezer for a few hours so the metal contracts slightly), take it out, heat the lock-nut slightly with a with a torch (so the nut expands), lay the nut straight on an anvil, put a ball-peen hammer on top and whack it hard with a sledge straight perpendicular on the nut (so shock will unfreeze the pressure where metal is jammed against metal), put it in a big bench vice, lock it down well, put the longest open end wrench you have on it-do NOT use a crescent as the jaws just don't stay tight and will round-over the vertices [corners] of the hex nut), slip a longer steel or iron pipe over the handle to get more torque, then have at it. Once loosened, the lithium grease mentioned above will be a good preventative to a repeat.
The reason one goes clockwise and the other counter, is so you can tighten and loosen it with both ends stationary, like a turnbuckle. If a 3ph implement is already attached, you can shorten and lengthen the link without disconnecting it. You loosen the lock-nut, adjust, then retighten the lock-nut, all w/o disconnecting the ends. The reason that rectangular loop is on the side is so you can slip in a big screwdriver, chisel end tire tool, pipe, etc. under it as a lever and get some torque to turn the thing in this manner.
   / Top link only shortens from one end?? #13
Snipe:
In some localities that is terminology for a piece of pipe that will slip over the handle of a wrench to give more leverage. :D
With combination wrenches it is not uncommon to combine two to get more leverage.:D
   / Top link only shortens from one end?? #14
Snipe:
Snipe: Around here I'd either be shooting it with a high powered rifle in a clandestine manner OR I'd be criticizing it in annoying, negative, or overbearing fashion. Either way, an observer would swear that I was the one malfunctioning, and the top-link was merely an innocent bystander. ;)
   / Top link only shortens from one end?? #15
Ever heard of snipe hunting? Some think that term is used in a facetious manner, but snipe truly is the common name for the avian genus Capella. All the species in this genus are shore and marsh birds, usually with slender bills. A sniper shoots at a distance from a hidden location to pick-off the snipe, whereas the practice of sniping involves hurling written/verbal epithets from a distant hidden or safe location (online, in newspaper, behind someone's back) in order to pick on someone.
   / Top link only shortens from one end?? #16
Yes, the different versions of "Snipe"
You fellows should come along on a Snipe Hunt usually conducted after dark!:D
   / Top link only shortens from one end?? #17
Yea, helped carry some folks on that kind'a snipe hunt in my younger years. Too old to pull that sort'a stunt now. It was a shock, when taking ornithology in college, to learn that snipe really existed.
   / Top link only shortens from one end?? #18
Snipe:
Ok! Hadn't heard that term before...have to admit I've sniped before;)
Got it loose finally and didn't manage to break anything or bloody any knuckles! Guess the penetrating oil needed to soak in a couple of days and a bigger wrench always helps too.
   / Top link only shortens from one end?? #20
Snipe:
Down here I call that a "cheater pipe" :)
(3) Military Transfer Cases (A50121)
(3) Military...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2015 Kubota SVL75-2 (A50120)
2015 Kubota...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
