Proper Wheel Torque? NH manual gives 2 specs
   / Proper Wheel Torque? NH manual gives 2 specs #1
sweep
Gold Member
Ohio hill country
2006 TC45A
I have a TC45A. On page 3-27 of the owners manual it says front & rear wheel torque is 95 foot lbs.
The specification page it says the front & rear wheel torque is 125 foot lbs.
Which one is correct?
Thanks
   / Proper Wheel Torque? NH manual gives 2 specs #2
I think my 2120 calls for 137 - 159#. 95 is more in the car range, so I'd go with the higher torque, as the bolts are bigger than a car's. 2120 is only a bit bigger than yours.
Jim
   / Proper Wheel Torque? NH manual gives 2 specs #3
My 2120 calls for 137 - 159#. 95 is more in the car range, so I'd go with the higher torque, as the bolts are bigger than a car's. 2120 is only a bit bigger than yours.
Jim
   / Proper Wheel Torque? NH manual gives 2 specs #4
Thanks
Page 3-27 in my older TC45D manual from 2001 says the torque for both front and rear wheel lugs is 125 ft-lb. I think that's your number.
I set the torque wrench to 125 and it clicked. Went up to 130, clicked.
Set it at 145 and it clicked and I stopped there
There was no movement at those settings.
I figure the dealer or the factory did not want them to come loose anytime soon.
GLEDHILL SPREADER (A52707)
GLEDHILL SPREADER...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55851)
Kawasaki Mule 2510...
Kubota B21 (A53317)
Kubota B21 (A53317)
2013 MACK ELITE LEU633 GARBAGE TRUCK (A57192)
2013 MACK ELITE...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
