Proper Wheel Torque? NH manual gives 2 specs
   / Proper Wheel Torque? NH manual gives 2 specs #1
sweep
Ohio hill country
2006 TC45A
I have a TC45A. On page 3-27 of the owners manual it says front & rear wheel torque is 95 foot lbs.
The specification page it says the front & rear wheel torque is 125 foot lbs.
Which one is correct?
Thanks
   / Proper Wheel Torque? NH manual gives 2 specs #2
I think my 2120 calls for 137 - 159#. 95 is more in the car range, so I'd go with the higher torque, as the bolts are bigger than a car's. 2120 is only a bit bigger than yours.
Jim
   / Proper Wheel Torque? NH manual gives 2 specs #3
My 2120 calls for 137 - 159#. 95 is more in the car range, so I'd go with the higher torque, as the bolts are bigger than a car's. 2120 is only a bit bigger than yours.
Jim
   / Proper Wheel Torque? NH manual gives 2 specs #4
Thanks
Page 3-27 in my older TC45D manual from 2001 says the torque for both front and rear wheel lugs is 125 ft-lb. I think that's your number.
I set the torque wrench to 125 and it clicked. Went up to 130, clicked.
Set it at 145 and it clicked and I stopped there
There was no movement at those settings.
I figure the dealer or the factory did not want them to come loose anytime soon.
Viewz VZ65UHD 65in 4K Security and Signage Monitor (A59231)
Viewz VZ65UHD 65in...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
UNUSED FUTURE FT13 EXCAVATOR (A60430)
UNUSED FUTURE FT13...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
