Storing plow
   / Storing plow #1
mayer2323
Member
After using my plow I coat it with greese for storage ,but I still get rust areas. Is there a better product to use or way to do It?
   / Storing plow #3
I've always used a brushed on coat of used motor oil. I've also heard of folks that apply a light coat of enamel spray paint ...
   / Storing plow #4
I always coat everything with used hydro / motor oil blend that I salvage at changes :D I even coat my metal parts on my tractors with it! Painted surfaces and all.........I know it helps.......I see the results between seasons.
   / Storing plow #5
i sprayed a light coat of paint on mine. As its been said before, paint is slicker and will rub off quicker than rust the next time you go to use it.
   / Storing plow #6
Wire brush,good washing,good primer spray paint,plow off the ground,tarp...works well.
   / Storing plow #7
My local Rural King and TSC carry a product in a spay paint can that goes on like flat black paint and wears off during use just for this purpose.
Chris
   / Storing plow #8
Chris
I believe what you are talking about is called plow coat. I have used it in the past but I have real good luck with grease myself. Plow coat seems to work real well too.
   / Storing plow #9
we always used grease from a bucket we kept just for that with a big paint brush. stays on even in the rain, comes right off soon as you drop plow in ground.
   / Storing plow #10
Fluid Film or LPS 3 are my favorite rust prevention sprays. Ive had great luck with both.
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
2013 GENIE S-85 TELESCOPIC MANLIFT (A51242)
2013 GENIE S-85...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
