Storing plow
/ Storing plow #1
mayer2323
After using my plow I coat it with greese for storage ,but I still get rust areas. Is there a better product to use or way to do It?
/ Storing plow #3
I've always used a brushed on coat of used motor oil. I've also heard of folks that apply a light coat of enamel spray paint ...
/ Storing plow #4
I always coat everything with used hydro / motor oil blend that I salvage at changes :D I even coat my metal parts on my tractors with it! Painted surfaces and all.........I know it helps.......I see the results between seasons.
/ Storing plow #5
i sprayed a light coat of paint on mine. As its been said before, paint is slicker and will rub off quicker than rust the next time you go to use it.
/ Storing plow #6
Wire brush,good washing,good primer spray paint,plow off the ground,tarp...works well.
/ Storing plow #7
My local Rural King and TSC carry a product in a spay paint can that goes on like flat black paint and wears off during use just for this purpose.
Chris
/ Storing plow #8
Chris
I believe what you are talking about is called plow coat. I have used it in the past but I have real good luck with grease myself. Plow coat seems to work real well too.
/ Storing plow #9
we always used grease from a bucket we kept just for that with a big paint brush. stays on even in the rain, comes right off soon as you drop plow in ground.
/ Storing plow #10
Fluid Film or LPS 3 are my favorite rust prevention sprays. Ive had great luck with both.
/ Storing plow #11
I painted mine with graphite paint. Don't know how it will work but it makes sense to me. I'll find out next time I use it.
/ Storing plow #13
I use some stuff that reacts with any rust and turns it to black iron sulfide, which is inert. Rust actually catylizes more rust formation.
Rust Oleum makes a version of it called Rust Reformer. You can probably buy it at Lowes and Home Depot or maybe any paint store. It's not a paint but a chemical that reacts with the rust.
I coated my snow plow with it, and any rust was turned black and shiney parts just stayed shiney.
NAPA has a product that does the same thing. There are/have been 3 or 4 differents brands of this same chemical.
You can paint over it, if you want.
Ralph
DOOSAN G25E-5 PRO 5 STRAIGHT MAST FORKLIFT (A62129)
DOOSAN G25E-5 PRO...
2016 CHEVROLVET SILVERADO 2500 TRUCK (A62130)
2016 CHEVROLVET...
2016 EH Wachs Trav L Vac Hydro Vacuum Excavator Trailer (A61567)
2016 EH Wachs Trav...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2018 EH Wachs Trav L Vac Hydro Vacuum Excavator Trailer (A61567)
2018 EH Wachs Trav...
