How to cut conveyor belt?
   / How to cut conveyor belt? #31
I guess when you use a chain saw it smokes a lot and slings rubber everywhere.
*I hadn't really thought about using a chain saw.
I have family that lives in Beckley and Beaver WV.
Me and my brother used to go and trout fish the cherry river.
I had, but he beat me to posting.
   / How to cut conveyor belt? #32
Guys, I'm a little spooked about using a chainsaw to cut conveyor belt. What keeps it from grabbing and kicking back?
   / How to cut conveyor belt? #33
The 3/4in. belt we used in the mines was tough.
You would think using a chain saw on rubber would give the chain grip and that would make it kick back.
   / How to cut conveyor belt? #34
This is coal mine belt and I didnt have any trouble I just took my time and let the saw do the work. I tried a demolition saw and it didnt work well, it smoked a lot and was grappy. Send it down my way and I will cut to length for a nominal fee. Hey this is West Virginia we do finish carpentry with a chain saw around here, as long as your not picky.:D
   / How to cut conveyor belt? #36
I worked on a Habitat house with a guy from West VA. He was all the time talking about making "West Virginia cuts." :D We had a lot of fun on that job.
   / How to cut conveyor belt? #37
Man, this thread brings back a lot of bad memories:) A couple years ago I had to haul blasted rock with my dump truck, so I lined the box with conveyor belt (I think it was 3/4" thick, maybe thicker?) Ended up just using a utility blade with lots of new blades, and keeping it wet with water while cutting. I'd score it first, then go back and cut. And yes, it was a pain:D
   / How to cut conveyor belt? #39
I have been thinking on your need to cut this heavy belting material....and I wonder about using an angle grinder with a cut-off blade to slit the belt? It may burn/melt about as much as it cuts....not sure...just a thought. :confused:
   / How to cut conveyor belt? #40
I was wondering Foggy...do they sell cut off blades that would fit a 4 inch angle grinder? I would have need of my grinder for some projects if a small cut off blade would fit. And that would save some money from having to buy a separate tool.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2014 Ford F-550 4x4 Ext. Cab Flatbed Service Truck (A52377)
2014 Ford F-550...
