Help My TC40D
   / Help My TC40D
Well, believe it or not, yoke shaft 24 broke right in the middle of the cam plate. It's welded super to the outside, but with a little wiggling, I can slide the pedals/shaft out far enough that the inside portion of 24 came out of the cam plate.
Who'd a thunk :eek:
   / Help My TC40D #12
I think I'm gonna cut a bigger hole and weld it while it's on, rather than try and take it off.
Thanks for your help.
I think you are onto something! An access plate under the rubber mat would be terrific, especially since the shaft goes through the B-plate at the top. That should work just fine.
BTW: When you cut that hole, be prepared for finding the whole bottom of the platform is rusted. It seems to be a common thread amongst owners that we all see great chunks of paint and rusty metal coming off in sheets under that platform.:mad:
   / Help My TC40D
Yes, an access plate should be there, and by jove! there's one there now:D
Only it's called a hole!
Weird where it broke, right inside the "B - Cam" plate.
I had a friend with a plasma torch cut it out, had to do a little sawsall work, and careful not to hit/burn the wire harness that runs under there, and then some welding (aprox. 75% around), re-adjust the neutral eccentric a smidgen, and we're on the go again.
It wasn't rusty top or bottom.
   / Help My TC40D #14
That is too cool for words. Great job!:)
Shindawa EC7600 Concrete Saw  (A52384)
Shindawa EC7600...
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
2014 Nissan Rogue Select S AWD SUV (A51694)
2014 Nissan Rogue...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
