3-Point Hitch MB265B 3 Point hitch will not raise
   / MB265B 3 Point hitch will not raise #1
stumpfield
Gold Member
Sierra Foothills
2005 MT265B
I got the equivalent of a 1533 (challenger MB265B). Never had a problem before. I parked the tractor for about a week. Now suddenly the 3 Point hitch will not raise. The front loader and all other hydraulic functions worked fine including the top and tilt. Any suggestion on where to look for potential problem? Thanks
   / MB265B 3 Point hitch will not raise #2
Do not know your tractor but does it have a valve under the seat to adjust the 3 pth? Many do. Is it possible someone played with it since you last used it and screw it in where the lift will not work?
   / MB265B 3 Point hitch will not raise #3
Not sure what set up you have, but it could just be a quick coupler hanging up.
   / MB265B 3 Point hitch will not raise #4
stumpfield- I thought for sure I broke something on my GC2310 when the 3PH wouldn't move, but kthompson's correct-- if that knob is screwed all the way in, the 3PH control won't do anything.
The knob's purpose is to control the speed at which the 3PH drops, with a "lock" position if it's screwed in (clockwise) all the way, like a faucet....
It's the knob on the left in the photo; the other one is for adjusting mower deck height. Maybe?
I have a similar knob. I turned it both directions but didn't make any difference. Today, I try it again then it suddenly works! I was able to raise the 3PH just once.:mad: After that it stop working again. I tried looking around to see if anything stuck but no luck. Any sugguestion on where to look specifically? Thanks.
There's a knob under the seat. I turned it back and forth but no help. I'm pretty sure no one plays with the tractor. It was working fine the last time I move the tractor. I have my boxblade on all the time so each time I move the tractor, I have to raise the 3PH.
   / MB265B 3 Point hitch will not raise #7
Try turning knob counter-clockwise to open valve, leave it that way, then allow tractor to run for a while; perhaps there was not much fluid and/or pressure in the system? Maybe you opened the valve, some pressure/fluid got in, and then you closed it again which allowed it to work only a bit? I'm really just guessing here, but it seems to me that it took several minutes for stuff to start working again after I changed the hydraulic fuid, too.
   / MB265B 3 Point hitch will not raise #8
Here are some possible causes from the service manual for a MF 1433 (Agco ST35):
Lift does not rise.
Insufficient engine speed
Insuficient transmission oil
Air leak through suction piping
Clogged suction filter
Maladjusted relief valve
Stuck sequential valve spool
Broken control valve
Broken slow-return check valve
Anyone know if the 3PH uses the same fluid as the rest of the hydraulic system. My loader, top and tilt all seem to work fine. I was able to raise the boxscraper about an inch off the ground to move the tractor using the top/tilt. Should I go ahead and change the hydraulic filter and fluid to see if it helps? Thanks.
   / MB265B 3 Point hitch will not raise #10
stumpfield-- on my 2310 (with hydrostatic transmission), all hydraulic fluid is the same system- for drive, FEL, and 3PH; all the same except for front axle.... I'm running out of ideas, but jhwentworth's checklist sounds like a good way to go- all control linkages seem OK?
1761 (A58375)
1761 (A58375)
2020 DRAGON ESP...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
