Make up my mind- Landpride or Bushhog
   / Make up my mind- Landpride or Bushhog #11
In regards to Bush Hog company. Bush Hog is too strong and too big to just disappear. There may be new owners in the future, but I believe that Bush Hog continue to be a driving force in this market. Their market share by most accounts is BIG.
   / Make up my mind- Landpride or Bushhog #12
I hope you are correct. But who'd of thought 3 years ago that GM may go bankrupt. Maybe Bushhog can get some bailout money.:eek:
Regarding the op. I have a 1672 Landpride finish mower, and a Bushhog SQ600. They are comparable in quality, with maybe the Bushhog being made a little heavier compared to other rough cut mowers than the Landpride is compared to other finish mowers. I wouldn't be scared of either one, and would probably choose on price and location if it was between the two.
   / Make up my mind- Landpride or Bushhog #13
I have the Landpride 6 foot cutter and also a rear finish mower. They are well built and I'd buy another. I looked at a few different brands before buying mine, and the two things that I liked about the Landpride was the 3 year warrantee that I got on my gear box, and the welds on the deck. Some of the other brands only had short welds, where Landpride had continuous welds.
I beat mine up pretty bad the first two years that I had it and caused allot of damage to it. I had the gear box replaced under warrantee, two drive shafts, four sets of blades and have had to re-weld the deck twice now. I called Landpride to find out the size of the nut that holds on the blades, and they were very quick to get back to me. I liked that.
Landpride is now sold and serviced through all Kubota dealers. My dealer is a good guy, but not even close to the professional level of my Kubota dealer. They don't stock allot of parts, but when they say they will order it, they do so and call me the second it gets in. The guy I bought my tractor from has a bad habit of forgetting to place the order, so I rarely deal with him if I have a choice to go somewhere else.
I have no experience with Bush Hog to compare the two of them.
Eddie
Eddie,
If you have done that much repair work on your cutter I would have to question why you think they are well made. I have taken woods cutter through (not over) many large rocks, T posts (2 and counting), barbed wire, gohper mounds, etc. The only damage I can see is dents from the inside where the blades tried to throw a rock through the side.
Where you using it in Iraq???
   / Make up my mind- Landpride or Bushhog #14
Around here there is alot of people running bush hog brand cutters old models and the newer models. Not to many land pride around yet. Me and my dad have an old bush hog brand cutter it is built like a tank. I would not be scared to buy a bush hog brand.
Sidenote to self DO NOT LOAN ANYTHING TO A GUY NAME EDDIE FROM TEXAS. He seems to be a bit rough on stuff.
   / Make up my mind- Landpride or Bushhog #15
I also have a BushHog Squealer. Have had for two years and no problems.
   / Make up my mind- Landpride or Bushhog #16
Eddie,
Not Iraq, but not what it was made for. :eek:
Don't really know how to describe what I did to the mower on a regular basis, but I also had to replace my front grill and both my fuel tank and hydraulic tank for my power steering. I had flat tires almost monthly, and I lost my fuel lines numerous times too. If I could drive over it, I did. If I couldn't, then I backed into it. I never let the size of the sapling limit me. If it went over, I shredded it.
I can cut up a four inch pines and two to 3 inch sweet gums.
If I wanted to clear an area, or create a trail, I did so for two years. I beat it and abused it well beyond what it was designed for. I'm still using it today, but it's not as pretty the day that I bought it. I don't know if there are other brands that would have done as well. I go through allot of tools and destroy them on a regular basis. If and when they die on me, I move on. If I got what I think is my moneys worth out of them, I praise them. If they die on me too quickly or easily, then I do the opposite.
I like Landpride, and I like how well built it is.
Eddie
   / Make up my mind- Landpride or Bushhog #17
I have a couple of bush hogs. They are both 6ft, one I haven't used yet, it has been setting for about 6yrs waiting on the other one to blow up. I got a deal on it I couldn't refuse.
As far as the one I am using, the first thing I did when I bought it is reinforce both sides with 3/8 flatbar 3/8 strap around the back and 3/16 up and under the main deck.
I use blades that are tipped up on the trailing edge so when you hit one of those rocks, logs, stumps or whatever, the back side of the blade deflects up to the deck before the forward cutting edge slices the deck open.
Experience talking here. I do some very heavy mowing and have taken on engine blocks, concrete you name it. don't ever listen to someone tell you, "oh there's nothing out there".
   / Make up my mind- Landpride or Bushhog #18
I bought the BrushBull 600. It has a 100hp gear box. After 9 years of total abuse that would make Eddie curl up in a quivering ball, it has had no problems other than breaking blades on the granite rocks, stumps, t-posts, buried tires, 3-4" oak, maple, poplar trees and the 5-6" softwood trees. It may not do as nice cutting grass as other units, but it guts it way thru the forest leaving a trail behind. (and I used the word "guts" intentionally!) If I can push it over, it cuts it up.
jb
   / Make up my mind- Landpride or Bushhog #19
... After 9 years of total abuse that would make Eddie curl up in a quivering ball...
Did I miss something or was there something offensive in my previous posts?
Guess I don't understand why you went there.
Eddie
   / Make up my mind- Landpride or Bushhog #20
Both companies produce fine products...
I ran a LP RFM for 14 years and never replaced a bearing...
They are great...
My father is a retired tractor/implement salesman...
They carried Bush Hog...
I can't tell you how many Bush Hog cutter's we've used on the farm...
Very well built and tough...
My only concern would be their financial situation...
I agree with one poster that Bush Hog may re-structure in some form...
I think that it would be highly unlikely that they would go away permanently...
Too much name brand recognition in that Bush Hog name...
I would personally go with the Bush Hog since it has a little heavier rated gear box if they were priced similarly...
2014 VOLVO EW210D MOBILE EXCAVATOR (A60429)
2014 VOLVO EW210D...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
BOMAG MPH100R SOIL STABILIZER/RECYCLER (A60429)
BOMAG MPH100R SOIL...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
