2000-2002 Chevy trucks and daytime running lights
   / 2000-2002 Chevy trucks and daytime running lights #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
I've observed something and that is that at least 1 out of every 4 2000-2002 Chevy truck I see has one of its little daytime running lights burnt out. For the owners of this era of truck (the best looking ones, in my opinion), are y'all replacing these bulbs every two weeks or something?
   / 2000-2002 Chevy trucks and daytime running lights #3
I've got a '99. The first couple of years I went through 1 about every 6 - 8 months. I then found a different type of bulb that was supposedly "double life" or something to that affect, but it was the same wattage. I don't think I've replaced a DRL since '02 or '03. I think a lot of it has to do with heat build up. I think those bulbs get hot running for extended periods of times. Now that I don't drive the truck to work an hour each way every day, I think that is why mine are now lasting.
   / 2000-2002 Chevy trucks and daytime running lights #4
I have changed mine once in about 4 years. About a month apart from each other, but it is not driven daily.
Dan
   / 2000-2002 Chevy trucks and daytime running lights #5
My 99 they lasted a year, sometimes 2. We have 4 newer pickups now they do seem to last longer.
Jim
   / 2000-2002 Chevy trucks and daytime running lights #6
I replaced three in one year. I don't worry about them anymore.
   / 2000-2002 Chevy trucks and daytime running lights #7
Mine go out on occasion and they're easy enough to replace so I do. Besides if one is burnt out it's just an excuss for the local's to pull you over. Usually will happen around closing time. I remember coming home from work late and it was just after closing, sure enough got pulled over for a burnt out light. Around here that's one way for them to catch individuals who have embibed to much.
   / 2000-2002 Chevy trucks and daytime running lights #8
I have an 04 with the driver side out right now. Been like that for nearly two years. Just not very high on the priority list to replace that bulb. In fact I'd rather not have them on anyway and usually flip the switch off.
That's cool that there's a switch. My headlights are constantly on on my 99 Chevy, and the only way to turn them off is to engage the parking brake, at least to the point where the electric switch is closed.
   / 2000-2002 Chevy trucks and daytime running lights #10
That's exactly how mine was. It's been a while and I can't recall if the truck was a '99 or '00. When I first went to test drive it I saw the emergency brake light on and asked the guy if he'd driven very long with the brakes on (wondering if there was any pad left). That's when he explained to me that he hated the lights and that was the only way he knew to turn them off. He said he'd rather look at the emergency brake light than drive with the daytime running lights on. Me? I took the bulbs out. I was going to just unplug them, but I couldn't see how to do so without the plug hanging down and getting road grit in it.
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2002 KENL 12 Ft Enclosed Trailer (A50324)
2002 KENL 12 Ft...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2012 John Deere 7280R MFWD Tractor (A52128)
2012 John Deere...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
