Pintle Hitch vs. Ball Hitch
   / Pintle Hitch vs. Ball Hitch #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Are their distinct advantages and disadvantages regarding pintle hitches and ball hitches?
Is one type quite a bit better than the other?
My 2008 F150 4x4 I think is limited to towing less than 10,000#.
TIA
Yooper Dave
   / Pintle Hitch vs. Ball Hitch #2
TIA
Yooper Dave
The heavier the trailer, the better a pintle hitch works. They're heavier constructed of thicker iron and IMO, they're coupling system holds on better.
For an F-150 towing, a ball hitch is more than adequate for anything you'll ever tow. Don't waste your time on a pintle hitch for an F-150.
   / Pintle Hitch vs. Ball Hitch #3
I have both, a pintle on my 5 ton dump and a 2-5/16 ball on my new to me 9K equipment trailer.
Was gonna put a pintle eye on the equipment trailer since it's the adj type and can easily be swapped, but since I got the solid insert with a 25,000 pound rated ball on it from the guy I bought the trailer from, I'm just gonna use this for now.
It's a little less movement with the ball, with pintle there's a little for and aft banging around. The pintle is a bit easier to couple.
JB.
Hi Builder,
The only reason I ask, is that there is a 8-9 year old 20' H and S equipment trailer for sale here locally (e-bay). I might go have a look, as it seems to be in fairly good condition.
It has the pintle hitch.
The trailer is 16' long + 4' beaver tail and ramps.
I am trying to figure out how much to pay if I deceide to buy.
I think it was stored outside.
Any advice regarding price?
Thanks
Yooper Dave
   / Pintle Hitch vs. Ball Hitch #5
Hi Builder,
Thanks
Yooper Dave
Ah, OK, that might be a good reason to buy a ball/pintle combination.
If it's a good deal and it has a pintle, then put a ball/pintle combination hitch on your F-150. If anything, you'll have more versatility. Let's say you buy that trailer with a pintle, but sometime in the future, you rent a logsplitter, a concrete buggy, etc and it has a ball hitch, you'll have both hitches in one hitch. :)
I can't imagine it'd be worth more than 2K.
Make sure you hook it up and tow it around to check the brakes, light functions, etc.
   / Pintle Hitch vs. Ball Hitch #6
All good advise here. The biggest problem I can see with a pintle hitch on a trailer being towed by any 1/2 ton truck like a F-150 is you can not use WD hitch which will be necessary with a trailer that big and a good load. If you look at the factory hitch on your F-150 it will have different limits for both strait pull and WD hitch on the placard. I think my 2007 F-150 is labeled 7,500# strait pull with 750# tongue weight, and 10,000# WD with 1,000# tongue weight although the tow limit on my particular truck is 9,240# after weighing it then subtracting that weight from the max GCWR of 15,000#. It is listed as 9,300# but I have lost 60# due to options and more than likely the tool box in my truck. By the way my truck weighs 5,560# with me and 3/4 tank. So 15,000-5,560=9,240
Chris
   / Pintle Hitch vs. Ball Hitch #7
I can't speak to their general suitability, but I can say that the combination of a pintle hitch and surge brakes is highly undesirable, especially on a (rented) trailer that has a tendency to sway no matter how you distribute the weight. The pintle hitch lets the trailer move around a bit more than ball hitch. Couple that with hitch-activated brakes and you've got a recipe for bad behavior even without the sway issue, IMHO. I will never haul another pintle-hitch trailer without electric brakes.
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
1995 Polaris 300 Explorer ATV (A59814)
1995 Polaris 300...
2020 DRAGON ESP...
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
