Jd 2305 & Single mold board plow !
   / Jd 2305 & Single mold board plow ! #21
Ray, he had the dealer put it on, it's actually a 2320 rops
   / Jd 2305 & Single mold board plow ! #22
Jim,
Thanks for the response.
Ray
   / Jd 2305 & Single mold board plow ! #23
To kvjohndeere and other members reading my post:
I just purchased this same JD one bottom plow from my local dealer for my 2305 tractor. My experience with plowing is very limited to about 30 years ago on my grandparents farm. So, I am real green and need some help from you folks.
Regarding this same setup as shown by kvjohndeere:
1) Have you had any issues with hooking the plow to the iMatch hitch versus just the regular 3PH? Does the lower link pins stay in the iMatch alright or do they ever pop out? Just wandering if I should remove iMatch and attach direct to 3PH hitch arms and upper center link to be safe?
2) Was there any preliminary adjustments I should make to the plow before starting?
3) Any potential problems to watch for during operation, based on your experiences?
4) Assuming I use front suitcase weights on the 2305, do I also need weights on the rear wheels?
5) Should I be engaging the 4 wheel drive when operating?
6) What engine RPM and ground speed do you recommend?
Thanks so much to everyone for any help.
I run My 2320 at around 1800 to 2000 Rpms You can use 4 whel drive if needed you really need to use front weights you can if you want ! I adjusted me Single moldboard plow to fit my my Imatch It works great I have done 3 gardens with it this year so far it is awesome ! write back if you need more info !
   / Jd 2305 & Single mold board plow ! #25
kvjohndeere.... Sorry about being so technical, but a couple more followup questions:
1) I have front weights, but not rear weights. Do I need to purchase some rear weights?
2) The JD Operator's Manual gives fairly detailed instructions for installing the plow. Did you raise up and support the left side of the tractor 6 inches to make all the pre-setting adjustments? For example, did you have to loosen the two U-bolts attaching the mast to the beam to adjust width??
3) Do you have to re-adjust plow to iMatch every time you remove and then reinstall.
Thanks again kvjohndeere. You are a great resource for us.
I have Just front weights Yes I adjusted My plow as The manual Said ! Once I put The plow on I didnt have to adjust anything with The Imatch !
   / Jd 2305 & Single mold board plow ! #27
And what ball park figure is JD selling this neat little plow for? I see Frontier is selling a 1 and 2 bottom plow but they don't have a gauge wheel or coulter disk. The 1 bottom sells for 723.00 on the build your own site.
   / Jd 2305 & Single mold board plow ! #28
that's about what I was quoted, ended up buying a leinbach for $350 and it plows just fine behind my 2305, but it's not imatch compatible.
   / Jd 2305 & Single mold board plow ! #29
The part # for the single bottom is LPPP1200JD. It is contracted out to Brindley.
   / Jd 2305 & Single mold board plow ! #30
Sorry, forgot to tell you it sells for $495.00 plus shipping. That is at my local dealer.
Mini Margaritaville Truck (A55853)
Mini...
Kubota L4701 (A53317)
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
CATERPILLAR D3 CRAWLER DOZER (A60429)
CATERPILLAR D3...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
