spray foam
   / spray foam #1
capt jack
North Texas
kubota M105,B21,Cat D6B
I'm in the process of converting an existing camper "carport" into a shop (my existing one is outgrown). Its 20'x36' 12 ft. tall. I've already poured the slab, I'll be walling it in soon. I thought I wanted to have the interior sprayed with the semi ridgid foam insulation (looks like the stuff that comes out of spray cans). The only guy I've talked to so far priced it at $1.50 Sq. ft. of wall/ceiling area. About $3000 , seems pretty high to me. What about it guys, anyone here had it done in the last few months that can tell me if thats a correct price? My neighbor has a shop twice as big as mine and said his was $2000 but that was 4 years ago. I do plan to get more bids, but not many choices around here.
Thanks! Jack
   / spray foam #2
I have no idea about the cost, but what material will you be spraying it onto; i.e, wood or metal walls and ceiling? I've heard nothing but bad stories about using it on metal, but if it's wood, I think it might be good.
   / spray foam #3
I looked into it last fall. I forget the prices but I do recall that it was the most expensive option for what I was doing.
There were even do it yourself kits on the net. That might give you an idea about the low end of the price scale.
   / spray foam #4
A friend of mine is a contractor that manages lots of duplex builds and just finished a new house for himself.
One of the things he did was use that on his house. not sure of all the details, but he has no vents at all in the roof and the house gets complete cooling.
This will serve as an insulation barrier and will work well.. BUT is has to go against wood. I think Eddie Walker can add more info here...
Later,
J
   / spray foam #9
I paid $2000 for my entire 1800sqft house back in 2001. That price included me shaving all the excess down to stud level instead of the installer. At that time, that was about 3x the price of doing my own fiberglass batt.
I will never use any other insulation again. the house is so tight now that the energy recovery unit (fresh air) runs more than the furnace in the dead of our Wisconsin winters. In the years since, my gas savings has more than made up for the extra cost of the insulation.
As for the metal buildings, I beleive there is a bonding product, similar to an undercoating, that they can apply first that bonds well to the foam.
Doug
   / spray foam #10
Bird, could you give more details on this? I recently built a 40'Wx60'Dx18'H metal shop. The builder talked me into using the closed cell foam insulation as it was "only about 15% more money than the batt and provided much more strength".. Beings I live on the Tx coast the additional strength the close cell would provide seemed to be the right choice.
Well the first estimate was $12K. I looked into do-it-yourself kits but it would take so many kits I would spend close to same amount of money and me doing all the work. So right now the shop is not insulated seems at this point short of pulling the metal off the building the spray foam is my only option?
Thanks for any advice on this.
Chuck.
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
2006 International 7400 Dump Truck (A47477)
2006 International...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2019 Generac Mobile MLT4200 20KW Towable Light Tower (A52377)
2019 Generac...
