JD 790 4x4 vs. TC 30 2wd
   / JD 790 4x4 vs. TC 30 2wd #11
O.K, just lanes, small food plots. I understand better now:D I would go with the 790. 4wd is a must with smaller tractors, pull better turn better. A 790 small stature is a natural for small lanes and food plots, not so big to be cumbersome, and surplus of power. The loader will come in handy.... just wait:D
Thanks to all for replies.Next question.What is the minimum length trailer I can get by with if I get the loader?
   / JD 790 4x4 vs. TC 30 2wd #13
18 ft, dual axles with brakes.
   / JD 790 4x4 vs. TC 30 2wd #14
The 18 footer I have fits my 790 and loader with a jd403 rotary cutter snugly. Its the longest 790/implement combo I have. Would not go any shorter.
   / JD 790 4x4 vs. TC 30 2wd #15
Wellllll.....not so fast here. I would like a longer trailer (18' er) if I had a large enough tow vehicle. Instead I bought a 7000 # GVW trailer.
What I'm saying is contrary to allot of advice on trailers (bigger is better) but I chose a 16 footer for my rig (14 + 2 beaver tail) as I have a SUV (GMC Acadia) and don't want excess trailer weight with my small tractor and implement....as the vehicle is not rated for such (and I dont want to buy another vehicle for my occasional towing needs). The tractor fits and loads onto this trailer just fine...and will balance the weight nicely.
Here's the math: Towing capacity 5400 lbs
Trailer weight (PJ 16) 1500
Tractor w/ extras 2400
Loader 700
fluid in tires 400
box blade 400
chains and micl 200
OK....I may be a a tad over the tow recommendations....but it's close enough for the girls I know. ;) However given a large enough tow vehicle....I also would pick the 18 footer.
   / JD 790 4x4 vs. TC 30 2wd #16
Don't hesitate about the loader; it will be as handy as a skinning knife... You will wonder how you lived without it!
If you are hunting deer then you have the perfect machine for handling them for cleaning and skinning.
   / JD 790 4x4 vs. TC 30 2wd #17
I was just loading my tractor for it's trip "up north" to my deer land....where I hope it lives a long life. :D Anyway....here is a pic of the tractor with loader and box blade on the 16 foot PJ trailer. I have about 1 foot to spare in deck length but it balances well. I believe I could put it on with my 5' KK cutter...but it would hang off the back about 2 feet. So...like others have said....an 18 is better if you have the choice and the vehicle to pull it. For me, this trailer will work out just fine, and its a bit more nimble to get around with my little rig. Hmmm...I just noticed that front chain should be moved to the back of the stake pocket.
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2014 FREIGHTLINER CASCADIA DAY CAB (A51219)
2014 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
