Big Tex follow up
   / Big Tex follow up #1
Propjob
Seacoast NH
JD 2305
Well:
After rewiring most of this beast when I got it and Emailing my problems to the sales dept....with no response, I've ended up with another SNAFU that I had to repair from BIG TEX. After sitting most of the first winter in my yard, it became necessary for me to use my new trailer. Well some of the lights did not work. After troubleshooting ( my profession) I found the mess at the main harness splice that I care to exhibit. Poor splice job on all conductors, wires hanging out of splices, insulation that looks like it was stripped with a machete and a poor tape job. If this product went out the door at my employer, it would be a life safety issue and not tolerated. We all love our tractors and our equipment, but look at these pic's and ask you Big Tex Dealer if they have changed the quality of their product.
   / Big Tex follow up
Well extra Pics from the file> Here are the ones.
JIM
   / Big Tex follow up #3
Butt connectors :mad::mad::mad:, And by the looks of it they're not even the right size. No excuse for that on a name brand trailer, but i understand most of them do it for the sake of "production". No heat shrink or wire loom either.
And people wonder why they have trailer lighting problems?
As you likely know, there is nothing like soldered and heat shrunk connection. Id expect no less. Also, I'd run a ground from all lights back to the tow vehicle. I have no luck relying on chassis grounds.
Thats some pretty lousy wiring, if i do say so myself.
   / Big Tex follow up #4
Bid Tex is a big name too. Think they would have paid more attention to that detail. I need to take some pics of the wiring of my BetterBuilt. I was pretty impressed. Not at all like the typical trailer wiring I've seen. 1 yr and no problems with it at all.
   / Big Tex follow up #5
I will not buy a trailer for my business or sell a trailer without a junction box and properly connected wires. That is very poor job done by Big Tex.
Chris
   / Big Tex follow up #6
Mine had wire loom and tape.. but still had the butt connectors. i rewire dthe trailer after fighting a few bad connections at the brakes a couple years ago..
soundguy
   / Big Tex follow up #7
That is some real crappy wiring, and I'm wondering if the dealer did the hack job prior to delivery instead of it coming from the factory.
   / Big Tex follow up #8
Mine had a top quality custom wiring system, but the manufacture didnt think so, and didnt protect with grommets thru the torch cut steel it passes thru. I cut little pieces of pvc and taped it in place of conduit.
I was told so many things are "industry standard" :mad: I dont like that for an answer.
   / Big Tex follow up #9
Mine had no grommets either.. I split some fuel hose to protect my wires going thru the angle iron frame.
soundguy
   / Big Tex follow up #10
I was having sever problems with my horse trailer and when I redid the wiring I ran everything through conduit with water tight couplings etc.
Pig Statue (A55853)
Pig Statue (A55853)
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
(APPROX 7) 10" X 20' CHANNEL IRON (A57192)
(APPROX 7) 10" X...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Caterpillar 257D (A53317)
Caterpillar 257D...
