What do you USE to HAUL your KUBOTA on/in?
   / What do you USE to HAUL your KUBOTA on/in? #31
Homemade deckover carhauler
   / What do you USE to HAUL your KUBOTA on/in? #32
I got a better pic yesterday of mine loaded.
   / What do you USE to HAUL your KUBOTA on/in? #34
Nice trailer's everybody.I am purchasing a 16' landscape trailer actually14' plus 2' for the tongue 7000lb GVWR. That should be more than enough for my BX -24. ANY more BX-24 trailer pictures?
   / What do you USE to HAUL your KUBOTA on/in? #35
Any rear attachments? you might want a 16' ....
   / What do you USE to HAUL your KUBOTA on/in? #36
I've been told many times on TBN that landscape trailers are to lightly built and flimsy to haul my BX23 on.
   / What do you USE to HAUL your KUBOTA on/in? #37
New to forum and tractor world. I just have an acre and found this old gem to use for leveling after garage construction and to keep the driveway up. Really, it's actual purpose is to be a toy. Trailer is 4x8. B5100 only weighs 800 lbs. Nice website and forum by the way.
   / What do you USE to HAUL your KUBOTA on/in? #38
Not yet, My trailer is still parked for the winter season. Are you sure you want a 14' ? With the BH mounted, it sure eats up alot of space and with the 14' , you will need to have BH turned sideways for better balance on trailer.
   / What do you USE to HAUL your KUBOTA on/in? #39
What size would you reccomend, with or without BH?
   / What do you USE to HAUL your KUBOTA on/in? #40
I haul my BX2200 w/loader, boxblade, and MMM on a 16' landscape trailer and it works fine. I usually put the tractor about 1 1/2' back on the trailer to get it balanced. With a BH, I would probably have to pull all the way forward to balance. Usually, there isn't much difference in price for the 2 extra feet and it sure comes in handy.
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
8 Ft Fork Extensions (A50322)
8 Ft Fork...
CATERPILLAR 299D SKID STEER (A51242)
CATERPILLAR 299D...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2014 Doyle Dry...
