My little GR thinks it's a BX now
   / My little GR thinks it's a BX now #1
locknut
Kubota
Here's a link to photobucket with some vids and pics of some recent mods to my GR2000.I know these are not designed to do this kind of work,so I give it frequent breaks to keep the hydro from overheating.So far,so good :)
Pictures by locknut-1 - Photobucket
   / My little GR thinks it's a BX now #2
Great pictures and videos. Your tractor looks to do well at those tasks..... even ripping your soil !
   / My little GR thinks it's a BX now #3
Is that a Trim Tab motor you are using to raise and lower your impliments?
Basically the same,yes.It's a 4" stroke ball screw I.E.I. 12V w/limiting clutches end of travel both directions and 1200lb/3000lb work load/holding load.It'll jack the rear wheels off the ground-no problem.
Wish I had a breaking plow.I think it would pull it no problem.The 4" clearance on the rear axle housing might be a problem though,plus mucking up the glidesteer clutch linkage on the right side.Still like to try it though,just for kicks.
   / My little GR thinks it's a BX now #6
That is an awesome setup! Did you build the sleeve hitch yourself or bought it? I'm interested in using a box scraper to level my gravel driveway also. What kind of cost am I looking at? Thanks.
   / My little GR thinks it's a BX now #7
There is nothing like that feeling when its doing the work you wanted it to do.;)
I puchased a generic sleeve hitch off ebay,made some improvements to it,then designed the framework for the tractor and had a local fab shop weld up the sub-assemblies for me.Probably have around $700 in everything.If I had a welder and a source for scrap steel I could have saved a couple hundred easily.
   / My little GR thinks it's a BX now #10
Pretty cool. Nice work. When will the front end loader be added :D
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
T-POST PULLER (A52708)
2017 Wanco WSDT3-S S/A Towable Radar-Speed Trailer (A55973)
2017 Wanco WSDT3-S...
EZ-GO golf cart (A56859)
EZ-GO golf cart...
2013 Wanco WTSP Folding Solar S/A Towable Arrow Board (A55973)
2013 Wanco WTSP...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
