My little GR thinks it's a BX now
   / My little GR thinks it's a BX now #1
locknut
Kubota
Here's a link to photobucket with some vids and pics of some recent mods to my GR2000.I know these are not designed to do this kind of work,so I give it frequent breaks to keep the hydro from overheating.So far,so good :)
Pictures by locknut-1 - Photobucket
   / My little GR thinks it's a BX now #2
Great pictures and videos. Your tractor looks to do well at those tasks..... even ripping your soil !
   / My little GR thinks it's a BX now #3
Is that a Trim Tab motor you are using to raise and lower your impliments?
Basically the same,yes.It's a 4" stroke ball screw I.E.I. 12V w/limiting clutches end of travel both directions and 1200lb/3000lb work load/holding load.It'll jack the rear wheels off the ground-no problem.
Wish I had a breaking plow.I think it would pull it no problem.The 4" clearance on the rear axle housing might be a problem though,plus mucking up the glidesteer clutch linkage on the right side.Still like to try it though,just for kicks.
   / My little GR thinks it's a BX now #6
That is an awesome setup! Did you build the sleeve hitch yourself or bought it? I'm interested in using a box scraper to level my gravel driveway also. What kind of cost am I looking at? Thanks.
   / My little GR thinks it's a BX now #7
There is nothing like that feeling when its doing the work you wanted it to do.;)
I puchased a generic sleeve hitch off ebay,made some improvements to it,then designed the framework for the tractor and had a local fab shop weld up the sub-assemblies for me.Probably have around $700 in everything.If I had a welder and a source for scrap steel I could have saved a couple hundred easily.
   / My little GR thinks it's a BX now #10
Pretty cool. Nice work. When will the front end loader be added :D
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2007 JLG 450AJ SERIES II SKYPOWER BOOM LIFT (A52709)
2007 JLG 450AJ...
PALLET TOTE OF BOAT MOTOR PARTS (A58374)
PALLET TOTE OF...
Doyle 6T Fertilizer Spreader (A56435)
Doyle 6T...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
