JoyStick Knob w/12V Momentary Switch
   / JoyStick Knob w/12V Momentary Switch #1
Scotty370
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
Does everyone have the same problem finding a reasonably priced Knob w/ a 12v button, to activate a Solonoid Diverter/Selector (Grapple) valve that I'm having? Think I saw one of you folks carving one out of wood. JR Meritt (OEM-supplier) has them, but I think I'd have to buy a hundred :eek:! I've checked the Motor-Head, racing sites, and Hurst Shifters, and B&M, have some for fifty bucks, and I still can't get the 1/2"-13TPI that I need, plus, I doubt they're waterproof. They use them for Nitro-Boost activation. Hey........wait! Maybe the 'ole JD would pick up a little more 'kick'!! :D ~Scotty
   / JoyStick Knob w/12V Momentary Switch #2
yeah, I am the woodchuck. What a PITA trying to find one.. but it was fun and it works. I got a quote of $130 plus outrageous shipping. Look in my posting there was a guy in AZ who did a really nice job with bondo on a wire frame with a rocker switch.
You only need one button to pick that valve I think.
I keep my tractor inside so I was not to worried about weatherproof.
   / JoyStick Knob w/12V Momentary Switch #3
Have you looked at Scorpion Technologies.
They have lots of handles and switches to choose from and will custom make them also. I contacted them last fall to get some switches for a 3rd function hydraulic kit. I have a handle that has knock outs in it and they hooked me up with the button switches to put in it. They are really reasonable and nice people to work with.
   / JoyStick Knob w/12V Momentary Switch #4
Did you buy direct from Scorpian?
Thanks JDK! I shot them an e-mail. I kind of like the trigger concept. I also found a weatherproof momentary locally ($10), and a block of Aluminum 1.25x1.25x4" long (free) to play with! Need to drill a 7/8" hole, 1-1/2" deep in the top to mount the switch, then Drill and tap the bottom. Then drill a wire raceway! Just seems like some thing so simple, should be ....."out-there".......! ~Scotty
   / JoyStick Knob w/12V Momentary Switch #6
Yes I did buy directly from them. We talked a great deal about what I wanted and then they emailed me a diagram and parts list. I gave the ok and they put it together and mailed it to me.
   / JoyStick Knob w/12V Momentary Switch #7
No problem Scotty. I found out about them from 3RRL.
Here are a couple pictures of my handle and the switches I got. I can't find pictures of the switches installed but will get them tomorrow.
   / JoyStick Knob w/12V Momentary Switch #8
Try Pilot Supplies, Avionics, and Homebuilt Aircraft Parts from Aircraft Spruce and Specialty Co. or other airplane supply. Airplanes use them for radio and flap control. Perhaps some of them would work for you.
http://www.aircraftspruce.com/catalog/elpages/ottopistolgrips.php
Some are pricey but there are few cheap one.
Darn, RIT, Ya 'bout had me choking when I popped up that site and saw a $500- joystick! The cost of the sleeve is more what I had envisioned! I was joking about the 'Nitro' comment, so 'wings' are totally out of the question! Seriously though, they did have some momentary switches that could be used. I kind of like the one I picked up. Just came up from my basement "Machine-Shop", (read that as, drillpress, assortment of unorganized drills, couple C-clamps,......well you get the picture...) and was able to drill out the top of the aluminum billet, 7/8" x1-1/2" deep. Think it's going to work! I've got to get a 27/64" drill and 1/2"x13 tap tomorrow. We'll see! I'll also see what Scorpion has to say! Thanx! ~Scotty
   / JoyStick Knob w/12V Momentary Switch #10
Search for grip and you will find some single switch grips.
Here is one for $37.50.
RAY ALLEN G101 STICK GRIP from Aircraft Spruce
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A52128)
John Deere 1110...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
