100 Series, are they worth it?
   / 100 Series, are they worth it?
actionaj said:
I had a L-130 used it to mow a little over an acre. Sold it last summer it had about 140 trouble free hours on it. I sarted mowing about 5+ acres had to get a bigger mower. But the L-130 was a good machine with a good cut.
What influence you not to replace your 130 with another JD?
   / 100 Series, are they worth it? #32
Just wanted to give a little update. I have been very very happy with the LA135 as it cuts well, is comfortable to ride, and it still looks great. I gave it its first oil change which I found pretty easy to do, and I could not be happier with the unit. I had the blades sharpened which improved the mulching. I learned that if you mulch and the grass is growing a lot, it's best not to wait a full 7 days, as you will have more clippings showing up on the lawn. But I am a Deere lover, and was pleased when JD sent me a free JD hat. I use it every time I cut the grass now. :D It sorta of makes me look more professional. ;)
Well I am now into my second year with my LA135 lawn tractor. I have used it twice so far, and it continues to give me a great cut, mulching, and no maintence issues. Hopefully this will continue for several more years. :D
   / 100 Series, are they worth it? #35
How many of you guys have added grease zerks to the mower spindles? I have that on my short list of things to do before mowing season starts. How much will this help extend the life?
Steve
100 Series
Buy a real John Deere not a cheap knock off.
If I had the money to buy the 300 series I would have. My choice was between a Sears Craftsman or a 100 Series Deere. Who the heck are you to tell me I have to spend more money to cut my grass. If this unit performs great for 10 years, and continues to do the job it has been doing, that I am happy.
   / 100 Series, are they worth it? #38
I think a better question would be is the deere 300 series that much better than the 100 series to cost 2-3 times as much?
It was around $1,100 more of the 17 hp 300. For what you get with better tires, transmission, engine, and frame, I would say it is worth it.
   / 100 Series, are they worth it? #40
Well,you might be right,but I'm not so sure.
My thoughts as I've said before,is if you want to buy a cheap lawnmower,than buy the cheapest one in the size you want,that you can find[husky,cub,sears,deere,or any other brand],cause,thats what your wanting and they all [in about same price range,cheapest ones] will be about same quality. But you will save a few hundred,by buying that cheapest one.
But,if you want to try and buy a good,fair priced,middle of the road one,its very hard,cause they ain't but maybe 1 or 2 of those.[and than your not real sure you did better than just buying a cheap one.]
Now if you can spend,over 4,000 dollars on a lawnmower,you increase your chances of getting a better quality mower,But I,[like about everybody,I see mowing their yards],don't have that kinda money to spend on just a lawnmower.
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A53472)
2015 Ottawa Yard...
Cat 305.5E CR Excavator (A52384)
Cat 305.5E CR...
2017 POLARIS RANGER 500 EFI UTV (A51247)
2017 POLARIS...
JOHN DEERE Q820M LOT IDENTIFIER 229 (A53084)
JOHN DEERE Q820M...
2018 John Deere 8400R MFWD Tractor (A53342)
2018 John Deere...
