Pros/cons pull type v. 3 pt mowers
   / Pros/cons pull type v. 3 pt mowers #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Other than the actual weight afforded by a pull-type mower what are the adv/disadv of pull type versus 3 pt mowers.
Worst disadvantage I can think of on pull-type is you can't raise mower for cleaning or clearing obstacles?
Anything else
   / Pros/cons pull type v. 3 pt mowers #2
Advantages of pull-type include:
Minimal 3-point lift capacity is required
Easier to hook up to tractor.
Doesn't apply leverage to tractor or change the center of gravity making bumps less noticeable.
Cons include:
Can't lift and back into brush - we do this regularly.
Can't easily get into square corners
As you noted, can't lift over stumps/rocks/other obstructions
For mowing wide-open pastures, pull type is great. Big mowers are usually pull-type. For close quarters a three-point type is generally better suited.
Mike
   / Pros/cons pull type v. 3 pt mowers #3
There are two pull types, I assume you mean a reel type where the ground wheels drive the mower blades, like the kind golf courses use to get a real fine cut. I have a Swisher 5' mower with a gas engine on it that I pull behind and next to my 5' 3pt bush hog to do the pasture. That gives me almost a 10' wide cut on each pass but I can drop the Swisher to use the bush hog alone to back in around overhanging trees and get in tighter places.
I should have been more clear-I meant the PTO driven pull-type. :eek:
   / Pros/cons pull type v. 3 pt mowers #5
Cons include:
Mike
I just leave the MM Mowers hooked up on of 2 of my tractors .
A rear mower would mean more adding and removing of attachments for me .
   / Pros/cons pull type v. 3 pt mowers #6
Anything else
The 3 point would be easier to load on a trailer if you had to mow in another location verses the pull type.coobie
   / Pros/cons pull type v. 3 pt mowers #7
"For mowing wide-open pastures, pull type is great. Big mowers are usually pull-type. For close quarters a three-point type is generally better suited....."
I would say that goes a long to summing it up. Pull-type mowers are better for larger plots and following the contour of the ground. Three-point types are better for smaller acreages, close quarters, utility cutting or where you need more maneuvering.
What size were you thinking about?
   / Pros/cons pull type v. 3 pt mowers #8
To point out what Joe said, one of the main advantages of the pull type is its ability to follow the ground contour. One disadvantage of 3pt mowers is that when you go over a ridge the mower lifts up then drops on the ridge so you get long and short grass from a 3pt mower unless you design it to float by using a chain which is a whole different thread.
Are you talking rotary cutters or finish mowers though?
My plan was a 7' rotary twin spindle 3 pt mower, but I wanted hydraulic height adjustment.
Only one I can find is made by woods and costs $6,500 :eek:
Just a "Tad" more than I want to spend:rolleyes: by about $4,000 :D
   / Pros/cons pull type v. 3 pt mowers #10
There are several that make 7' mounted rigs..........and for less than $6500.
7' M.H.D. CUTTER W/2 WHEELS W/CH [MH72TC] - $3,023.00 : Howse Implement Company, Your source for tractor and farm equipment parts and supplies
Heavy Duty Rotary Cutters
And if you're not absolutely set on a twin-spindle rig there a scad of others out there that will sell you a 7' cutter for less.........Kodiak, Mohawk, Taylor-Pittsburgh, Modern Mfg, King Kutter, Big Bee, etc.
There are a lot, but I don't think any of them off hydraulic height adjust. I need that feature. Woods is the only one I can find that has hyd height adjust.
   / Pros/cons pull type v. 3 pt mowers #12
You can raise pull type bush hogs I dont know what any of you have been around but Ive been around plenty of pull types that lift with a standard 3 x 8 cylinder. Woods and other companies make these.
Given my choice, I'd like a 3pt, 7-foot, twin spindle, hydraulic raise/lower rotary brush mower for ~$2,000. It will probably a used unit, as long as it is in good shape.
   / Pros/cons pull type v. 3 pt mowers #14
Check out Kodiak Manufacturing Mowers KODIAK MFG., Inc. I just bought their 10' Pull Type from our Mahindra Dealer for $4,600 including hydrualic lines and cylinder.:eek:
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
