Removing a bush
   / Removing a bush
lol, easy out, easy in.
Small project for a backhoe, but everytime I use it I get better at it. And looking at that area tonight, I think I'm going to go with grass seed. That bush was in a dumb spot.
   / Removing a bush #42
New post "how to plant grass seed"
   / Removing a bush #43
   / Removing a bush #44
Ahhh...grass seed. Is it a mostly sunny location Freds? I would go with the zoysia. Kentucky Bluegrass...nah. Centipede...full sun in the south and slow growing. Pennsylvania, I see. They don't have grass up there do they?
Don't do anything yet. We will advise you on grass and how to plant...
   / Removing a bush
Let's see... which would be best for planting grass seed backhoe or FEL? :rolleyes:
I figured I'd use the FEL with the toothbar on it. That way I'll be able to rake it in with the toothbar and cover a larger area. I might carry the bag of seed in the BH's bucket....
:rolleyes:
   / Removing a bush #46
New implement time. You need 3pt sprayer so you can water it.
   / Removing a bush #47
ah, hand seeding, just walk around tossing handfulls into the front of your backpack blower lol.
   / Removing a bush #48
Even better. Bore a hole in the bottom of the blower wand, and insert pipe with a 45 degree end into the hole about halfway in the tube, with the 45 degree facing forward. Causes a vacuum, Then put the other end in a bucket of grass seed, and blow. It spreads it out real good.
   / Removing a bush
Hmmm, no backpack blower....
I'm sure I could come up with something that would work with my snowblower though!
   / Removing a bush #50
How about pouring some diesel fuel on it and torching it.
Kubota SVL95-2 High Flow Cab Skid Steer (A55218)
Kubota SVL95-2...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2011 JOHN DEERE 670G MOTORGRADER (A51406)
2011 JOHN DEERE...
