Removing a bush
   / Removing a bush
lol, easy out, easy in.
Small project for a backhoe, but everytime I use it I get better at it. And looking at that area tonight, I think I'm going to go with grass seed. That bush was in a dumb spot.
   / Removing a bush #42
New post "how to plant grass seed"
   / Removing a bush #43
   / Removing a bush #44
Ahhh...grass seed. Is it a mostly sunny location Freds? I would go with the zoysia. Kentucky Bluegrass...nah. Centipede...full sun in the south and slow growing. Pennsylvania, I see. They don't have grass up there do they?
Don't do anything yet. We will advise you on grass and how to plant...
   / Removing a bush
Let's see... which would be best for planting grass seed backhoe or FEL? :rolleyes:
I figured I'd use the FEL with the toothbar on it. That way I'll be able to rake it in with the toothbar and cover a larger area. I might carry the bag of seed in the BH's bucket....
:rolleyes:
   / Removing a bush #46
New implement time. You need 3pt sprayer so you can water it.
   / Removing a bush #47
ah, hand seeding, just walk around tossing handfulls into the front of your backpack blower lol.
   / Removing a bush #48
Even better. Bore a hole in the bottom of the blower wand, and insert pipe with a 45 degree end into the hole about halfway in the tube, with the 45 degree facing forward. Causes a vacuum, Then put the other end in a bucket of grass seed, and blow. It spreads it out real good.
   / Removing a bush
Hmmm, no backpack blower....
I'm sure I could come up with something that would work with my snowblower though!
   / Removing a bush #50
How about pouring some diesel fuel on it and torching it.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
