Repair/mechanic tricks and or tips?
   / Repair/mechanic tricks and or tips? #541
Can't get anything done that way!!
   / Repair/mechanic tricks and or tips? #542
if you need to dill out a broken bolt that is broke off down in a hole and if you have access to a lathe drill a hole in the center of a bolt the same diameter, then put the bolt into the hole and use the same size bit to drill directly into the center of the broken bolt. if you have a left handed drill bit it mite just screw the bolt out. or use an easy out.
   / Repair/mechanic tricks and or tips? #543
Soundguy said:
Ditto on the cheap wrenches. I have a set from kmart that has never broke.. it must be 20ys old.. I also have a shiny chinese set.. still never broke one.
Lessee.. tips...
Stuck nut.. heat joint and then apply candle wax.. the wax will seep into the joint by capilary action, and act as a lube when you do go to unscrew it.
Have a stuck bearing race that you can't get a 3-jaw puller on? Weld a small bead around the ID of the race.. it will either fall out when cool, or will drop out with minimal force.
A center punch makes a good dimple for drilling to prevent walking.. I know someone already mentioned filing a flat on round stock.. these can be used in conjunction, and do work out well.
Soundguy
when drilling round stock with a drill press ram the bit into th stock fast back off and drill maybee turn the piece if neccesery
   / Repair/mechanic tricks and or tips? #544
I don't know if anyone posted this yet. I save all of my old heater hoses and radiator hoses and use them to cover hydraulic hoses that rend to rub against the tractor frame, especially on the fel. I split them and fasten them with cable ties. It also works for wires of other lines that are at risk of wearing thru.
Jeff
   / Repair/mechanic tricks and or tips? #545
Jeff
Good recycle! I thought that was what old garden hose was for but had problems with small diameter sometimes.
Pat
   / Repair/mechanic tricks and or tips? #546
I think I had seen this tip/trick on a car site and had occasion to use it yesterday changing the oil in my van. You take a 2 liter jug and cut the top out so an oil filter will fit in and unscrew the filter letting it fall into the jug and all the dripping oil goes into the jug as long as you hold it in place. All that oil I used to have to wipe up from the frame is now neatly in the jug.
   / Repair/mechanic tricks and or tips? #547
Great tips! Keep them flowing.
With all of the talk about strong and super magnets, I have not seen a caution about keeping the magnets away from credit/bank cards and their magnetic strip. Magnets will scramble the data and make the card useless. No need to ask how I know....
   / Repair/mechanic tricks and or tips? #548
Yeah, don't want to be like a friend whose wife "POSTED" his new credit card on the refrigerator door (you guessed it) with a magnet.
Pat
   / Repair/mechanic tricks and or tips? #549
Wow what a good thread !!!! Lifetimes of experience you cant learn in a book.
Learned this from an old time machinist. The problem was a broken stud below the surface of an exhaust manifold. It was a stainless stud in an aluminum manifold. I have used this procedure probably 25 times with 100% success rate. Use a wire feed welder and build up the the broken stud above the surface enough to get a pair locking pliers on it. Use a little extra heat on the first weld to get a good bond to the broken bolt, then turn it down (the welder) and build it up to the height you need. Its already hot and comes right out every time. This could also be used on rounded nuts, bolts, stripped phillips, ect. You get the drift. Happy welding.
   / Repair/mechanic tricks and or tips? #550
A very simple trick that has served me well for years is to clean up and put your tools away when you finish what your working on.
My father somewhat ingrained this into me, by his lack of doing this.
WALT
I couldn't help but relate to this statement.
My father and his pet employees lose more tools in a day than I buy in two years.
Even with seven trucks, numerous trailers, tractors, outbuildings, barns, shops, etc., I know exactly where any tool I own is at, even those used once every thirteen years.
My father, on the other hand, will usually give up looking and buy another, as it is quicker/easier for him.
He runs a public business where tools are used constantly; they spend more time looking for a tool than they spend doing the task that the tool was needed for.
Needless to say, I have learned to never let them around my stuff.:rolleyes:
2016 Ford F-450 12FT Flatbed Truck (A51691)
2016 Ford F-450...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Year: 2014 Make: Ford Model: F-450 Vehicle Type: Pickup Truck Mileage: 193,532 Plate: Body Type: 2 (A51692)
Year: 2014 Make...
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
