where to set jack stands?
   / where to set jack stands? #1
/pine
Super Star Member
for B2400,B2100,B1700 models
where is the best place to set jack stands at the rear?
is there a place to set a jack to only raise one side of the rear?
   / where to set jack stands? #2
under the axle. But if ya got a backhoe, just use the outriggers.
there is no room to set a jackstand under the axle the wheel/tire is too close...
If I had a backhoe I would not need jackstands
I intend to use a bottle jack under the center...eveyone says to use jackstands for safety...I've read that you have to be careful where the jackstand are set...?
   / where to set jack stands? #6
I use the outriggers to raise the machine, but I put two jackstands under the axle before I crawl under there...
   / where to set jack stands? #7
Is the case strong enough to lift the tractor from? I've heard stories of the case being broken when a floor jack was used on it.
I hope to get to this sometime this week...I intend to put the bottle jack under and lift at the draw bar...comments?
   / where to set jack stands? #9
"lift at the draw bar" sounds like a good, safe place to me.
International 404 Tractor (RUNS) (A50775)
International 404...
2010 Dewalt Air Compressor (A55787)
2010 Dewalt Air...
2016 Peterbilt 567 Tri Axle Dump (A47477)
2016 Peterbilt 567...
Chevy caprice (A55758)
UNUSED Quick Coupler (A47477)
UNUSED Quick...
