where to set jack stands?
   / where to set jack stands? #1
/pine
Super Star Member
for B2400,B2100,B1700 models
where is the best place to set jack stands at the rear?
is there a place to set a jack to only raise one side of the rear?
   / where to set jack stands? #2
under the axle. But if ya got a backhoe, just use the outriggers.
there is no room to set a jackstand under the axle the wheel/tire is too close...
If I had a backhoe I would not need jackstands
I intend to use a bottle jack under the center...eveyone says to use jackstands for safety...I've read that you have to be careful where the jackstand are set...?
   / where to set jack stands? #6
I use the outriggers to raise the machine, but I put two jackstands under the axle before I crawl under there...
   / where to set jack stands? #7
Is the case strong enough to lift the tractor from? I've heard stories of the case being broken when a floor jack was used on it.
I hope to get to this sometime this week...I intend to put the bottle jack under and lift at the draw bar...comments?
   / where to set jack stands? #9
"lift at the draw bar" sounds like a good, safe place to me.
Decorative Metal Butterflies (A55758)
Decorative Metal...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2016 Ford E-450 LP Handicapped Bus (A55788)
2016 Ford E-450 LP...
CFG Industrial H15R (A53316)
CFG Industrial...
Decorative Metal Butterfly (A55758)
Decorative Metal...
