Backhoe Jinma backhoe hydraulic fittings
   / Jinma backhoe hydraulic fittings #11
You can also get the 9022F metric face seal adapter at www.discounthydraulichose.com
We offer all of the Adaptall metric fittings at 10% to 15% below list price, and we stock a large number of them for same day shipping. We also carry hydraulic hose, quick disconnect couplers, and all of the other other fittings and adapters you to maintain your hydraulic equipment.
Ken Hutchinson
Discount Hydraulic Hose
800-535-1302
   / Jinma backhoe hydraulic fittings #12
Well, I searched through my receipts and could not find where I purchased a male x male adapter. The ones I had must have came with the tractor.
   / Jinma backhoe hydraulic fittings #13
Some of you know the 9022F converts the 18mm male ORFS to a Jic 8 male.
By me trying to help owners with replacement aftermarket hoses for the China Backhoes ..... I feel /felt that the Jic 8 is to big / bulky especially up at the control valve.
I am having some of these adaptors being made as I type that will adapt it the a Jic 6. I hope to have the first run in about two weeks ??
I will be able to provide the adaptors only or adaptors with aftermarket 2 wire replacement hoses.
Anybody that has any interest can email me through my web site Jinma Dealer, Wood Chipper , Compact Jinma Tractors . Put 18MMXJIC6 in the subject line and I will let you know more as I do.
Ronald
Ranch Hand Supply
   / Jinma backhoe hydraulic fittings #14
Ronald, I agree with you. I had always felt that the #8 was too big for the hoe since it is 1/2" ID.
#6 (3/8") would be optimum given the OEM pump's GPM output.
As you probably are aware, LiTW hoes use #4 (1/4") hoses and fittings. I think it is one of their engineering features that helps to seemingly dampen the jerky valve motions, aside from having better valves too.
   / Jinma backhoe hydraulic fittings #15
Bob or Ronald
Would switching to a #6 or #4 hose reduce the jerking of the hoe and would it still perform properly?
Thanks
   / Jinma backhoe hydraulic fittings #16
Ronald, As you probably are aware, LiTW hoes use #4 (1/4") hoses and fittings. I think it is one of their engineering features that helps to seemingly dampen the jerky valve motions, aside from having better valves too.
Bob or Ronald
Thanks
From what I have seen so far (my opinion) the biggest reason for the jerky /un-smooth operation that some have / experiance is that the spool valves are to loose in it's bore ...... a to loose machining tolerance.
The factory adaptors between the valve body and the hose have a orifice machined in them that goes to each cylinder.
A #4 hose would have a lower flow rate with a higher pressure and a #6 hose would have a higher flow rate with less pressure. A good control valve makes a world of differance.
Ronald
Ranch Hand Supply
   / Jinma backhoe hydraulic fittings #17
Our first adaptors has just been recently made and tested.
We have started a page on our web site that is under construction.
I will be receiving with in the next 7 - 10 days adaptors available for purchase.
These adaptors will allow you to up-grade / replace the hydraulic hoses and replace the control hydraulic valve with a quality aftermarket valve if you choose.
Click here; http://ranchhandsupply.com/replacementparts/chinabackhoehydraulic.html
Ronald
Ranch Hand Supply
   / Jinma backhoe hydraulic fittings #18
I made my own adapters a couple years ago to JIC. If you look at the hose pic you can see why they come apart. The hose was only inserted half way.
2000 Gallon Fuel Tank W/Pump (A50774)
2000 Gallon Fuel...
14" Pipe Ditch Lift Pump (A50121)
14" Pipe Ditch...
John Deere M Tractor (NOT RUNNING) (A50774)
John Deere M...
2025 Platform Safety Basket Attachment (A50322)
2025 Platform...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
