Opinions on 25HP dsl w/ MMM under $7,500
   / Opinions on 25HP dsl w/ MMM under $7,500 #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Looking for opinions/ideas/suggestions on buying a used ~25HP diesel with 62"-72" MMM for cutting large piece of grass quickly. 4WD would be desireable. $7,500 would be my upper limit, so I don't
even know if I'm being realistic.
I don't want a front-mount mower style tractor, but may buy one if I can't find a tractor that fits my budget. There seems to be a plethera of them available.
I've found a couple Deere 955's w/ 72" decks. That's the size/capability tractor I want. Happy to look for other brands, too.
A flail mower on my Challenger isn't going to work. It's far too heavy for lawns.
   / Opinions on 25HP dsl w/ MMM under $7,500 #2
We run New Holland eco tractors and the similar styled Fords. We have:
TC30~72" deck, 30hp
Ford 1520~72" deck, 24hp
Ford 1620~no MMM, just uses 3pt implements, 28hp
We are happy as can be with these tractors. In fact, when we only had 4 tractors, that 1520 was one and did the most jobs. They are the best. About the same size as a 955. I guess I'll tell a little story.
We had the 1520, and we didn't want to have to keep on switching from MMM to 3pt implement. We were getting another New Holland to mow, so that the 1520 could garden. First, we got a TC25 w/ loader. That didn't stand up to the 1 less HP 1520. So, then we got a TC40. That was a beast with an 84" deck. But, it still didn't mow right, i.e. clumps of grass. Then, we got the TC30. That was the only one that fit our needs exactly.
They are cheaper models, easy to climb on and off of. Have great hydro trannies. Wonderful workers. All ours are hydros.
I would like to give a warning: our Kubota/NH dealer says that these particular hydros go out at about 1500hrs. We haven't experienced it, though. Our highest hour Ford/NH is about 1150hrs.
Good Luck!!;):)
Kyle
Easy fellas! Not so many opinions...... it's only a tractor website. :D
Guess very few guys own 25HP diesel lawn tractors around here. :D
   / Opinions on 25HP dsl w/ MMM under $7,500 #4
:D
We own one and love it. Use it for other things too, but for lawn work, the thing is awesome!!
   / Opinions on 25HP dsl w/ MMM under $7,500 #6
Need more details!!!
Size of MMM, type of trans, cost, etc
60"MMM, 2 speed HST, bought new, they list for around $14,500. We could not find anything used, either way overpriced, or total garbage, so new we went!!
Yeeeouch! :eek:
I need to spend 1/2 that. :eek:
72" MMM would be more desireable.
   / Opinions on 25HP dsl w/ MMM under $7,500 #8
Yeeeouch! :eek:
Depending on the size of tractor you find, a 72" will not be good, too much scalping because the tractor may be to small to handle it. We had the choice of a 72", but the 60" was recommended for this model.
Keep us posted.
   / Opinions on 25HP dsl w/ MMM under $7,500 #10
Builder I would keep my eye out for either a Kubota BX2350 used(60" deck) or a older B model which could come with a 72" deck. If you are willing to get one with some hours, I think you can stay in your bubget.
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2003 Ford F-150...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
