ernemats
- Joined
- Mar 29, 2002
- Messages
- 1,079
- Location
- Bolivar, pa.
- Tractor
- power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
On the 1845 is there any heat shield below the muffler? On my 1845 1996 model with Deutz engine it looks like there was a bracket beside the starter that I wonder if it could have held a shield of some sort. If I run the tractor and the temp. gets hot it will not start for several hours unless you jump it, the battery tests 12.8 volts and when it is running it is putting out 14.7 volts . My neighbor thinks the starter is getting too hot from the muffler heat. I checked it after running till hot and the starter was about 190 degrees, and the muffler was off the scale. Any ideas?
