Price Check Price check on aisle 3....NH TC 55D...
   / Price check on aisle 3....NH TC 55D...
Thanks Thumper, glad you enjoyed it!
Mike :D
   / Price check on aisle 3....NH TC 55D... #22
BTW, if you have any shrubs, brush to get rid of those rock forks work great. Just drive in with them at ground level and parallel to the ground and lift and continue to drive forward a little. Out pops the brush/shrub roots and all. Also works with small trees but you may need a saw if one gets stuck between the teeth.
Andy
   / Price check on aisle 3....NH TC 55D... #23
! Thanks for putting up with such a long post!
Mike :D
This is not a long post. The forum has many mostly/absolutely useless posts many times longer.
Andy
BTW, if you have any shrubs, brush to get rid of those rock forks work great...
Andy
Great tip Andy! Thanks!
I had a major disappointment yesterday while I was moving equipment around. I just went from reverse to forward and the stinkin' shuttle lever broke off in my hand! :mad: I got the TC55 back to the shop and pulled the bottom cowling off and saw the lever had broken right at the weld to the mounting block. I was able to put the bottom of the rod into the mounting ears where the block would go and pinch it tightly with the bolt. This will work until I get another.
On a brighter note, I took it out today with the Woods RM990 and cut the back pasture. Man, I am in LOVE!!!;)
Mike :D
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2009 Honda Pilot AWD SUV (A50324)
2009 Honda Pilot...
