What to do before tilling?
   / What to do before tilling? #1
gregkabob
Moore, OK
NH TC45DA
I'm planning to put in some watermellons and pumpkins this year. I'm a greenhorn at farming and I would like some advice on what I should do before I till the area.
The property we purchased has not been worked in 20+ years. The area I want to plant in is covered with native grasses and we have clay soil. I have a subsoiler, disk, 2 row plow and of course a tiller at my disposal. Do I just go out and till the area or should I first run the plow, subsoiler or disk first?
Thanks for the advice, I need it :D
   / What to do before tilling? #2
well not really knowing your soil Id try it first if it throws the tiller around stop, and try something else either the plow or the disc even the subsoiler.
what ever works easiest
then get back to tilling
   / What to do before tilling? #3
From someone who has never run a tiller on a tractor.
First I would walk the property and check for debris that need to be removed. Second, how tall is your grass? Is it thick enough it could clog or stall the tiller? If you were not using the tiller looking at your equipment, I would disk it and then run the subsoiler and then disk it again for this year's planting. If it were fall I would subsoil it and let it sit. If you don't need to subsoil it (best way I know to find out is to test it either with shovel or subsoiler) then save time and money and don't.
This Okie soil is pretty tough stuff. The grass is about 1.5ft tall but not very dense as it's native grass. We've had a lot of rain this past week so once it dries out for a few days it will make the ground eaiser to work. I've already walked the area checking for debrie. I tried the subsoiler when I got it in that area and could get it to run pretty deep without a problem and that's why I picked that spot to plant and it seems the soil isn't as hard as some of the other places on the farm.
I was just wondering if most people that use tillers just go at it with the tiller right off the bat on new ground or use other implements first to loosen it up.
Thanks for the advice fella's.
   / What to do before tilling? #5
I plow then disk then till. I find that if I try to just till I end up going over the same place a few times trying to get a nice seed bed. Plowing and disking is much faster than tilling and then I only need to till once or twice at the most. Its easier on the equipment too.
   / What to do before tilling? #6
I've read a number of posts in the past few weeks that suggest cutting over it with a brush hog before tilling. This seems to reduce the propensity of the grass wrapping around the tiller shaft and clogging things up.
   / What to do before tilling? #7
My 5 ftkk tiller will just chew 2 ft winter rye up,it doesn't seem to be any problem as far as wrapping around anything.
If you got a turning plow,you should plow it first,than either disk and till or just till.
   / What to do before tilling? #8
Since your fields are native warm season grasses, I'd try just using the tiller first. If it were fescue, I'd definitely, want to plow it and maybe use a disc before using the tiller. Good luck. It'll all work out for you eventually however you go at it.
   / What to do before tilling? #9
Lots of suggestions and no absolute right or wrong answers. Since the land hasn't been worked in several decades I think I'd run the sub soiler over the area first to loosen up the soil deep. Since you have a plow, I'd use it next to turn under the grass and their roots. Next you could either use the disk or possibly go directly to the tiller. Want to work the soil a good 6-8 inches deep before planting.
Greg, see you're in Moore. Have family E of town on 149th out past Draper. Cousin is deputy chief for the OKC PD.
   / What to do before tilling? #10
I would grab something cold, climb on the tractor and plan for a relaxing day. I would run my tiller over it several times, lowering it each time. After a pass or two I would walk it to get the big rocks off to the side. Then I would ride over it with the tiller until it got to the deepest passes, lowering each time I passed, stopping occasionally to get the bigger rocks out.
I would plan on getting more cold drinks throughout the day.
Cutting the grass first won't hurt a thing, and would make it finer for tilling in anyway.
Enjoy. Nothing like some freshly turned earth to remind us of what matters in this world.
UNUSED RAYTREE RMA42 HYD AUGER SET (A57193)
UNUSED RAYTREE...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
2001 KOMATSU PC220LC-6LE EXCAVATOR (A52707)
2001 KOMATSU...
(1) 5' FOLD UP TRAILER RAMP (A57192)
(1) 5' FOLD UP...
2017 Ford Transit Connect XL Cargo Van (A55852)
2017 Ford Transit...
