SMV is illegal on a Tractor capable of exceeding 25MPH
   / SMV is illegal on a Tractor capable of exceeding 25MPH #22
I can tell you from experience that 25 mph is really moving with a farm tractor, especially if you are towing something. My MF 5455 will top out in the 24 to 25 mph range, with or without a round baler in tow. On a smooth highway it is not bad, but you do not want to attempt it on a road that is the least bit bouncy or that has a lot of patches, you WILL find yourself bouncing off the side of the road faster than you ever believed possible.
   / SMV is illegal on a Tractor capable of exceeding 25MPH #23
So what do put on the tractor capable of greater than 25 mph??
I know, a wheelie bar!
Seriously, I would not want to go 40 or 50 mph on a tractor. I'm not too experienced but even with my limited use that thought makes me nervous.
   / SMV is illegal on a Tractor capable of exceeding 25MPH #25
wish my 50 hp tractor could go 25 mph. Especially with a bunch of mad bumble bees chasing me.
I made a dumb mistake of shifting to neutral going down a long steep hill on a county road. There was no other vehicle's around as I was from bar ditch to bar ditch and afraid to touch the brakes and having one wheel brake before the other. My wife was following me in the truck pulling a hay rake. She said we were going way less than 30 mph. Felt like 60 mph to me.
   / SMV is illegal on a Tractor capable of exceeding 25MPH #26
The main reason I got the road transmission (40KM/hr) is that then added electrohydraulic MFWD wet clutch instead of a manual clutch. The clutch engages with the brake pedal (i.e., is partly for braking apparently) but I wanted the button on the dash to engage 4wd more easily on demand than a lever would be. And yes, I really like the rocker switch vs. a lever...
The down side is that ALL the gear ratios are taller so the very lowest and slowest creeper is sometimes just a bit too fast.
   / SMV is illegal on a Tractor capable of exceeding 25MPH #27
Some tractors used in Europe are designed to go fast. They have front spring suspension and the new one also have four wheel brakes.
   / SMV is illegal on a Tractor capable of exceeding 25MPH #28
I drove my new to me MF 5455 home last week and it has 40 km/hr (25 mph) gears in it. It runs a whole heck of a lot better on our rough secondary road than my little Kubota. I kept it at 40 km/h the whole 20 km drive home. Stuff that throws me in the air in the Kubota at 20 km/h was nearly unnoticed in the bigger massey at 40.
At the high speed though I did get into a bucking bronco rock for a stretch that I didn't even notice in the Kubota. I should note the MF has softride on the loader which is nice for quieting things down and the 3 point has active transport (like softride) so in the winter with the blower on I'll have less banging.
   / SMV is illegal on a Tractor capable of exceeding 25MPH #29
In Iowa there used to be a bunch of road tractors for hauling Corn stock bales into the plant. They could hit 50 MPH with 16 round bales on a auto aod trailer. Unfortunatly the stock plant jsut could'nt make plywood out of stocks that you could drive a nail thru.
87in Toolbox/Workbench (A57453)
87in...
(8) UNUSED 9' X 5' WROUGHT IRON SITE FENCE (A58376)
(8) UNUSED 9' X 5'...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAHP71W77X101435 (A57453)
2007 Ford Crown...
Homemade Farm Wagon (A57149)
Homemade Farm...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
