TN75 info
   / TN75 info #11
sorry just now got a chance to check on this for you. the tires name is Amercian Farmer and the size is 16.5L x 16.1
   / TN75 info #12
I work at a new holland dealership and I have had 2 tn75 traded in within the last month, they just wanted something bigger. It will aldepend on what you are trying to do with it. We also put up silage and silage bales, the silage bales were sometimes weighing over 2000 lbs and that tractor will not handle that.
   / TN75 info #13
Sure will
I've lifted many a pallet of fertilizer with my TN75
That's 2500lbs plus the pallet, in a 40x48 pallet.
works fine, doesn't even strain.
   / TN75 info #14
I agree with LoneCowboy, there is something ? about this statement. My TN75 will easily lift 3000 lbs. I have moved many 2000 lb round bales without any problems including stacking them 3 high on a semi flatbed. Sure a larger tractor would make it easier but that type of work is well within the capabilities of a TN. It is not within the capabilities of a compact.
Andy
   / TN75 info #15
So... did you pull the trigger on a TN75? They are good, solid, dependable tractors. Don't think you'll go wrong with one!
   / TN75 info #16
TN75 should handle upwards of 4,000 pounds ( properly ballasted of course). No matter what tractor you end up with, if it has a loader put fluid in the rears.
   / TN75 info #17
For 4000 lbs, fluid plus 1200 to 1500 on 3 pt hitch
Andy
   / TN75 info #18
Not sure about the tn75, but I have a 2002 tn90 FWD and it is one nice tractor.
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53472)
GALAXY - SET OF...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
New/Unused 78in Quick Attach Rock Bucket (A51573)
New/Unused 78in...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
