Kubota B3200 vs Kioti DK35se
   / Kubota B3200 vs Kioti DK35se #1
demoman357
Southwestern Oregon
Bobcat CT335, Case 480C
I am two weeks away from purchase. My primary need is to mow a 10 acre mini golf course currently maintained by 3 riding mowers. The Kubota weighs half the amount of the Kioti but is priced only 1,000 less. Ground pressure using turf tires is important (so I am told). Any suggestions, which should I get, why?
   / Kubota B3200 vs Kioti DK35se #2
There is no question that I would buy the B3200 for that mowing application. Some companies offer an extra large turf tire for their tractors like Massey, and Deere, but I don't know if they are available for the Kioti, and you do give up the option for a mid mount mower with the DK I believe. Not only is the extra weight, and size a consideration, but the DK's while great tractors are not the manuverability champs by any means. I would almost look at the CK35 with oversized turfs, and gang mowers on back for that application before I would consider a DK.
   / Kubota B3200 vs Kioti DK35se #3
What type of mower will you be using?
The mower I will be using is a 72 inch rear finish mower with side discharge. I would like to go to a 90 inch but I am worried about PTO horsepower. The Kioti DK35se HST does have slightly less turning radius on the paper specs and does have a turf tire/wheel option.
   / Kubota B3200 vs Kioti DK35se #5
The Kioti DK35se is actually a 38hp tractor but with HST would be 27 at PTO. I'd think that it could run a 90 inch finish mower so long as the mowing was done regularly.
The Kubota is 32hp with 23 at PTO. A more direct match to the B3200 is the Kioti CK35 which has just about the same HP at PTO. It is still heavier than the B by a thousand pounds or so but has bigger turfs I believe so ground pressure may not be that different. The CK is generally configured with features not found on the B Kubota line and I'd guess it costs a thousand or two less than the Kubota too.
Still, there is no question the Kubota is lighter and that lighter is generally an advantage for finish mowing applications.
Pallet Fork Backing/Spear/Reese Hitch Combo (A47371)
Pallet Fork...
305 E2 CR, Open Rops Excavator (A47371)
305 E2 CR, Open...
2019 Cadillac XT5 SUV (A48082)
2019 Cadillac XT5...
TOFT 680 Hyd Hammer (A49251)
TOFT 680 Hyd...
John Deere 2WD 40 Tractor (A49251)
John Deere 2WD 40...
Flail Mower (A49251)
