Weeds In One Of My Pastures . . .
   / Weeds In One Of My Pastures . . .
ddivinia said:
It can be tough at times.
Have you talked to your county agent? They have plenty of people that can help you out.
D.
I'm going Monday.
   / Weeds In One Of My Pastures . . . #22
I went thru the day study and test.
It is a "no brainer" and you will learn a lot.
D.
D.
You are referring to the applicators test correct?
   / Weeds In One Of My Pastures . . . #24
Down here the county agent puts on a class and preps you for the test. 1 day - class and test. It rocked - was long, but a 5 yr license out of it.
D.
D.
I'm exactly sure how it is done locally but I will find out next week. I was told that the local Coop can help you prep for it but I'm not holding my breathe. Hopefully the extension office will do that.
On the topic of the weed wiper, I assume you are using a tractor mounted model? What size are you using? As far as 12 volt power, what did you use for your source?
   / Weeds In One Of My Pastures . . . #26
tractor mounted
15'
I use the accessory bus on my 5525, First started using the cig lighter port, but I put the optional expansion port
I can post some pics if you want.
d.
ddivinia said:
tractor mounted
15'
d.
Yes, would love to see some pictures.
Seriously thinking about a 6ft model. I think 10ft. would be a bit cumbersome for some of my smaller paddocks. An 8ft. would be nice but I don't know if a custom built is more expensive. A bit torn to be honest but 10ft. might just be worth it in the long run as we expand into more land.
I need to look into wiring a 12v power source as I don't currently have bus or cig lighter.
   / Weeds In One Of My Pastures . . . #28
IT ISN'T LINDINO CLOVER. IT IS A WEED. GRAZON WILL KILL IT AND LEAVE YOUR GRASS. JUST GO DOWN AND TALK WITH YOUR LOCAL FARMERS SUPPLY OUR COUNTY EXTENSION AGENT. THEY WILL HELP YOU RESOLVE THE ISSUE.
   / Weeds In One Of My Pastures . . . #29
Why not make your own I'm in the process of making one at the moment it's a 8' carpet roller type I just had to buy the tank pump and carpet the rest is made from bits and pieces I had around the yard here's here is a give you a better idea this is just the solid works image
   / Weeds In One Of My Pastures . . . #30
Depending on what you are targeting, their might be a good herbicide to kill it. My problems are getting so much better, I might sell my grassworks unit in the next year or so.
D.
2011 Retesa CT7622 150 Vacuum Tanker Trailer (A52377)
2011 Retesa CT7622...
Krause Dominator 4850-18ft (A55301)
Krause Dominator...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
