300X or 300CX what is the difference?
   / 300X or 300CX what is the difference? #1
FRIZ
NW Indiana
John Deere 4720 Cab
Hi::)
I am planning to buy a John Deere 3720.
Please explain the difference between the 300X or 300CX loader.
Thank you,
Regards,
FRIZ
   / 300X or 300CX what is the difference? #2
CX=quick park/easy removal and higher capacity. Someone else may have specs--I don't have them off the top of my head
Thank you.
   / 300X or 300CX what is the difference? #4
Hi frits, CX lifts more weight and a little higher at pivot and has power beyond options unlike the than 300x . Only real difference is the size in cylinders I believe. More attachment options for the CX too. Wish the 790 came standard with at least the 300x instead of the 300.
   / 300X or 300CX what is the difference? #5
The 300x and cx both are quick park the lift height and capacity are the main differences. The 300x will lift a like 1325lbs and the cx about 1560 if memoery serves. The cx has a prgressive link on the dump cylinders. Otherwise I believe the cx just has larger cylinders. I think the cx isn't too much more than the x. And you can never have too much capacity right.
Matt;)
   / 300X or 300CX what is the difference? #6
   / 300X or 300CX what is the difference? #7
the cx does have larger cylinders. the cylinders will also hold up to repetitive use better than those of the x.
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
MINI EXCAVATOR BUCKET 24 (A55745)
MINI EXCAVATOR...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
STEEL SLINGS (A54757)
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
