300X or 300CX what is the difference?
   / 300X or 300CX what is the difference? #1
FRIZ
NW Indiana
John Deere 4720 Cab
Hi::)
I am planning to buy a John Deere 3720.
Please explain the difference between the 300X or 300CX loader.
Thank you,
Regards,
FRIZ
   / 300X or 300CX what is the difference? #2
CX=quick park/easy removal and higher capacity. Someone else may have specs--I don't have them off the top of my head
Thank you.
   / 300X or 300CX what is the difference? #4
Hi frits, CX lifts more weight and a little higher at pivot and has power beyond options unlike the than 300x . Only real difference is the size in cylinders I believe. More attachment options for the CX too. Wish the 790 came standard with at least the 300x instead of the 300.
   / 300X or 300CX what is the difference? #5
The 300x and cx both are quick park the lift height and capacity are the main differences. The 300x will lift a like 1325lbs and the cx about 1560 if memoery serves. The cx has a prgressive link on the dump cylinders. Otherwise I believe the cx just has larger cylinders. I think the cx isn't too much more than the x. And you can never have too much capacity right.
Matt;)
   / 300X or 300CX what is the difference? #6
   / 300X or 300CX what is the difference? #7
the cx does have larger cylinders. the cylinders will also hold up to repetitive use better than those of the x.
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2015 FREIGHTLINER M2 24FT BOX TRUCK (A56138)
2015 FREIGHTLINER...
TRANSMISSION JACK (A55745)
TRANSMISSION JACK...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
ATHEY AB6905 MOTOR GRADER (A52707)
ATHEY AB6905 MOTOR...
