Row hipper/builder manufacturers
   / Row hipper/builder manufacturers #1
Big_Cajun
South Central Louisiana
MF 1130
I've been doing some surfing on the internet for a single row hipper that would attach to my 3pt. I drive a Kubota M7040 (68 engine HP) and was wondering if anybody could help me locate a manufacturer.
Also looking for a 3pt. disc harrow as well as a wheeled drag type.
Any help would be appreciated.
BC
   / Row hipper/builder manufacturers #2
Big_Cajun,
I saw a small one row (hipper) unit at Progressive Equipment in Cecilia a few months ago, it appeared to be painted similar to "Howse" brand equipment. It had a cat I three point hitch and I suspect your 7040 may only handle cat II. You may want to give them a call. Hope this helps...
Thanks JKUB...actually, I think I can swing Cat. I or II implements. I'll give Dudley a call and see what he can do.
BC
   / Row hipper/builder manufacturers #4
BC,
If Dudley doesn't have what you are looking for you can check with Cain's Tractor off of Cameron St. in Lafayette. They carry a good selection of Howse equipment. The phone number there is (337)261-5743. Keep us posted on your search.
Jude
   / Row hipper/builder manufacturers #5
STEvENS TRACTOR: ROUTE 1 BOX 32: COUSHATTA LA 71019:
PHONE 800-333-9143:
Stevens Tractor Under Contruction, Coming Soon!
Their website is currently under construction. I was in their store the other day, and I asked when the website would be done. The answer was not encouraging.
For a large tractor like yours, get the heavy duty model, and not the garden model. Your tractor would tear the light one up.
Sevens Tractor implements actually build their tools right behind their store in Coushatta,La
I'm looking at a set myself.
   / Row hipper/builder manufacturers #6
I bought the garden row hipper from Stevens, couldn't ask for a better tool!
   / Row hipper/builder manufacturers #7
BC
With that much HP you could easily pull 2 or more rows at once I would think. I easily pull a one row with three discs per side with my JD 850 which has about 25 HP. You could buy a larger row crop multi-row implement (6-8 rows) and cut off the excess leaving 2 or 3 rows then sell the remainder in one or two row versions. HTH.
ARKAYBEE
   / Row hipper/builder manufacturers #9
I built mine,I purchased a TSC cultivator and added the 16 inch disc from Agri-supply;a little scrap steel.Mine bolts on,it can be removed to use just the cultivator.To answer the question wat a hiller is;it forms the rows for a garden(raised bed).
   / Row hipper/builder manufacturers #10
nybirdman, I am not trying to be a smart-*****, but you have the discs backwards on your hipper setup. If you turn them around so that the cupped surface of the disc is on the inside, they will do much better. Please don't take this the wrong way, just trying to help.
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2013 International (A53314)
2013 International...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2024 Ford F-350 Truck Bed (A53316)
2024 Ford F-350...
