Ran out of gas
   / Ran out of gas #11
It should start and run on wd40 keep spraying it till it starts it will run rough but it should run. Is the battery up to full charge it has to have enough speed to fire on compression.
BTW do you have an electric fuel shut down valve check for voltage if you also have a manual fuel shut down make sure it is on.
   / Ran out of gas
ill keep trying with the wd-40 but i thought i was spraying enough and im not sure about the fuel shut off but i dont think thats the problem if i was getting fuel to the injectors.
   / Ran out of gas #13
Did you remove the air filter.. IE.. you should be spraying inthe wd straight into the intake pipe after the filter..
soundguy
   / Ran out of gas #14
Don't forget it has to turn over fast enough to fire on compression .
   / Ran out of gas #15
soundguy
What do you think soundguy he will use about a can of WD40,that loader is probably 150 hp
   / Ran out of gas
i am spraying directly into the intake with out the filters and i have it hooked up to another vehical for plenty of cranking power. But your saying i should spray a whole can into it
   / Ran out of gas #18
Does this engine have glow plugs or grid heater are the glow plugs working.
   / Ran out of gas #19
What kind of a question was that???
I can look out my office window and see a line of equipment like that. the GC i work for has models in that line.. I'm quite familiar, and have driven big yellow iron.. scraper pans, graders, loaders, track hoe's, dozers, rubber and steel wheel rollers.. etc.
soundguy
   / Ran out of gas #20
so i used almost the whole can and still nothin. Im about to give up.
If it was gonna hit it would have done it almost immediatly..
soundguy
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
17101 (A53421)
17101 (A53421)
2008  BIG TEX 16' T/A TRASH TRAILER (A53843)
2008 BIG TEX 16'...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
ALUMINUM HEADACHE RACK (A53843)
ALUMINUM HEADACHE...
