Ran out of gas
   / Ran out of gas #21
G'day the white smoke is either the unburnt fuel or the WD if you can get your hands on a can of ether give it a three second shot whilst cranking and it should fire straight up as i have said before it is a very handy tool when used responsibly :)
Jon
   / Ran out of gas #22
I agree also... a can of "instant engine" should be in everyone's shop.
   / Ran out of gas #23
head bolt loosener? ;)
soundguy
   / Ran out of gas #24
Not sure what you've done so far, but start by bleeding filters, then bleed to lift pump, then to injector pump, then bleed the injector pump itself, and FINALLY bleed each individual injector. Just a little air CAN cause the entire fuel delivery system to air lock.
Don't even tell me if you've used ether. :eek:
   / Ran out of gas #25
You guys act there is something wrong with ether.:confused:
   / Ran out of gas #26
There's nothing wrong with ether itself.. however.. there is alot wrong with the average person and how much ether he uses for an application.
soundguy
   / Ran out of gas #27
soundguy
Anybody here remember the "purple ether pills", you could use more than one but it helped to limit the dose. They were standard equipment with a Detroit diesel in the cold!!
   / Ran out of gas #29
G'day you don't change spark plugs with a hammer what i am saying is used correctly a can of ether is a very handy tool, yes you can go overboard with the stuff but you dont need to run the engine on it for minutes on end, all i am saying is that we used to have a 3208 that if you ran it out of fuel you could use tern sets of batteries bleeding and cranking and it would not bleed the injector itself a, a quick sniff and by getting it to fire you would raise the inj pressure high enough to bleed the inj and away it would go. It's not addictive if you need to use it all the time then your prob lays deeper than ether. Anyhow enough of my raving give it a sniff and best of luck:)
Jon
   / Ran out of gas #30
what i am saying is used correctly a can of ether is a very handy tool, Jon
And what we are saying is it is very rare to find someone who uses it correctly.
you might have wanted to run that cat3208 into the dealer... we have plenty of 3208 powered yellow machines.. I don't recall ever needing ether to recover from a loss of go-juice. :(
soundguy
2005 CHANDLER FRAC TANK (A53843)
2005 CHANDLER FRAC...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
2005 Freightliner M2 106 Box Truck (A52377)
2005 Freightliner...
2007 International 4300 Dump Truck (A51692)
2007 International...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2010 FORD F-150 (A53843)
2010 FORD F-150...
