Oil & Fuel Oil Seal on TC55DA Front Axle.
   / Oil Seal on TC55DA Front Axle. #1
Osconda
Texas, Williamson County (aka Texas Hill Country)
New Holland TC55DA, delivered 05/25/2005
Hello Folks,
I have a very slow leak on the front left axle. Enough to accumulate a lot of dirt on the wheel between washings. I'm going to replace the seal but wanted to get some idea of what this job entailed.
Since it's front-wheel assist it looks like I have to pull the axle. Not sure though. I haven't taken anything off yet.
Anybody done this kind of repair before? Any advice? I should have everything I need in the shop except the seal ($55) which I haven't purchased yet.
   / Oil Seal on TC55DA Front Axle. #2
Hello Folks,
If it is the axle shaft seal leaking, it's quite straightforward. Have a tube of anaerobic gasket eliminator available to seal the reduction gear cover. Even the swivel seals aren't difficult. I routinely replace either on tractors on-site. Ford 10 and 20 series compacts and all the later NH compacts use the same designs, if not the same parts.
   / Oil Seal on TC55DA Front Axle. #3
Hi Rick B, When you say routine, are we talking 2 to 4 hours with the seal? Any special tools required?
Thanks, Coolhand
   / Oil Seal on TC55DA Front Axle. #4
A properly sized seal driver and a well stocked toolbox. Less than 2 hours for a first timer, less than an hour with practice.
   / Oil Seal on TC55DA Front Axle. #5
RickB - Thanks for the reply. Seal is on the way from Messicks. I have the seal driver - I looked at the assembly closely, seems pretty straightforward. Appreciate the info
Coolhand
LOT: Uline 72" Rolling Staircase, 6' Fiberglass Stepladder (A59076)
LOT: Uline 72"...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
Service Truck Hydraulic Rear Liftgate (A55787)
Service Truck...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
